native_ sqrt not supported with SDAccel?
According to the latest SDAccel manual that I've found online, native_ sqrt is not supported with SDAccel. If correct, then how would I go about calling my Kintex-7's CORDEC square root native method from my SDAccel C++ program running on my host OS over PCI-E?
You can try using a C/C++ kernel with access to much of the HLS syntax and Pragmas, which should allow you to implemnt something like this HLS example of the IP for performing a sqrt function https://github.com/Xilinx/HLx_Examples/tree/master/Math/sqrt_cordic
