Observer race
Accessing uninitialized memory -- works on CPU emulation.
The following code is an optimized opencl implementation on GPU. I am trying to run the same code on SDAccel but the HW emulation gives lots of warning that I am trying to access uninitialized memory. The output is not correct, but the functionality is right on CPU emulation.
// TODO: Add OpenCL kernel code here.
__kernel void gaus(__global uchar16* input, __global uchar16* output)
//Opencl constructs to get program parameters
uint x = get_global_id(0);
uint y = get_global_id(1);
uint width = get_global_size(0);
uint height = get_global_size(1);
//calculating source and destination index
uint dst_index = 16 * y * width + x;
/* src size is increased by 16 and border added */
uint src_index = 16 * y * (width + 2) + x + 1;
//uint src_index = y * width + x;
//perform calculation
float i0; float16 i1; float i2;
float i3; float16 i4; float i5;
float i6; float16 i7; float i8;
float16 Gx;
//pixel data
i0 = convert_float(((__global uchar*)(input+src_index))[-1]);
//printf("%f",i0);
//i0 = convert_float((__global uchar*)(input+src_index)[-1]);
i1 = convert_float16(input[src_index]);
i2 = convert_float(((__global uchar*)(input+src_index))[16]);
src_index += width + 2;
i3 = convert_float(((__global uchar*)(input+src_index))[-1]);
i4 = convert_float16(input[src_index]);
i5 = convert_float(((__global uchar*)(input+src_index))[16]);
for(int i = 0; i < 16; i++)
//collect new data
i6 = convert_float(((__global uchar*)(input+src_index))[-1]);
i7 = convert_float16(input[src_index]);
i8 = convert_float(((__global uchar*)(input+src_index))[16]);
Gx = ((float16)(i0, i1.s0123, i1.s456789ab, i1.scde)
+ 2.0f * i1
+ (float16)(i1.s123, i1.s4567, i1.s89abcdef, i2)
+ 2.0f * (float16)(i3, i4.s0123, i4.s456789ab, i4.scde)
+ 4.0f * i4
+ 2.0f * (float16)(i4.s123, i4.s4567, i4.s89abcdef, i5)
+ (float16)(i6, i7.s0123, i7.s456789ab, i7.scde)
+ 2.0f * i7
+ (float16)(i7.s123, i7.s4567, i7.s89abcdef, i8)) / 16.0f;
output[dst_index] = convert_uchar16_sat(Gx);
//reuse old data
i0 = i3; i3 = i6;
i1 = i4; i4 = i7;
i2 = i5; i5 = i8;
dst_index += width;
Tags (2)
Observer race
Re: Accessing uninitialized memory -- works on CPU emulation.
host side image padding
copyMakeBorder(input_image, image_pad ,1 ,1 ,1 ,1 ,BORDER_REPLICATE, Scalar(0));
copyMakeBorder(image_pad, image_pad ,0 ,0 ,15 ,15 ,BORDER_CONSTANT, Scalar(0));
