Can someone test Sobel example on SDAccel 2018.2 ?
Hi, I noticed that the edge detection example (Sobel filter) from my SDAccel 2018.2 examples produces a garbled image, see the attached image.
I use the kcu1500 hardware emulation.
Soft emu is working fine.
Is it possible for someone to cross-test that please ?
Re: Can someone test Sobel example on SDAccel 2018.2 ?
Just to give an update:
This issue is not seen in 2018.3, which will be released soon.
brucey
Before test it, just to make sure that you're using 2018.2 not 2018.2xdf?
brucey
How can I check that ?
What's the difference please ?
Hi, @xil_tour
Menu -> Help -> About Xilinx SDx.
These are 2 different SDx versions, just like 2018.1 and 2018.2.
I got:
Xilinx SDx v2018.2 (64-bit)
SW Build 2258646 on Thu Jun 14 20:03:40 MDT 2018
I can see this issue in 2018.2 xdf. We'll investigate further.
brucey
brucey
Ok, thanks for your time.
