Observer fpga2017
Do I have to install all the Linux packages listed in ug1238?
I'm installing SDx, in ug1238, it requires about 30 packages (such as: ocl-icd-libopencl1, opencl-headers, ... etc.) installed by 'apt-get install' command, so do I have to install these packages one by one? Or it will be installed automatically when I install the OS? Thanks!
Re: Do I have to install all the Linux packages listed in ug1238?
It seems some packages' names for Ubantu are incorrect.
Please try the below command:
sudo apt-get install ocl-icd-libopencl1 opencl-headers ocl-icd-opencl-dev linux-libc-dev g++ gcc gdb make libopencv-core-dev libjpeg-dev libpng-dev libtiff5-dev python git dmidecode pciutils strace perl libboost-dev libboost-filesystem-dev gnuplot cmake lm-sensors lsb unzip linux-headers-$(uname -r) python3-sphinx-rtd-theme sphinx-common python3-sphinx libuuid1 uuid-dev mokutil wget openssl
sudo apt-get install libjpeg62 libjpeg62-dev
Hi, @fpga2017,
You can install multiple packages at once by using the command below:
sudo apt-get install [package_1] [package_2] [package_3]...
Observer fpga2017
I failed to install a few of the packages, such as linux-libc-dev, libopencv-core, libpeng-dev, opencv, etc. For example, when I was trying to install opencv package, I got this error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package opencv
Thanks!
Observer fpga2017
Very helpful advice! Thanks! You should help them update ug1238, that will help many other engineers.
Good suggestion. I will.
