Fast Math
Hi there,
I'm curious about how functions like cos and sin, as well as log and exp, are implemented when called within a kernel. It seems to me that they might be a bottleneck for my applications.
Is there a way to choose lower precision implementations for speed, resources and lower latency? I'm thinking about things similar to native cosine calls or fast math from opencl.
Re: Fast Math
Hi @bandi,
SDAccel supports native math functions. They are optimized for Xilinx devices as described here.
The native functions are listed in the middle of this page.
Best,
-Dutch
Re: Fast Math
you can use hls function
https://github.com/Xilinx/HLx_Examples
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug902-vivado-high-level-synthesis.pdf
use dsp IPs
https://www.xilinx.com/products/intellectual-property/dsp-and-math.html
you can also use dsp48 primitive directly
https://www.xilinx.com/support/documentation/user_guides/ug479_7Series_DSP48E1.pdf
Thanks and Regards
Balkrishan
Re: Fast Math
I was asking more along the lines of xocc flags which control the implementation of math functions, or calling a specific, lower precision, math function at opencl code level.
Of course I can use CORDIC IPs and such, but that doesn't really apply when starting from OpenCL.
Re: Fast Math
Hi @bandi,
Best,
-Dutch
Re: Fast Math
I am sorry. Could you please help me :)
I want to use erf and erfc function. But, they don't work.
which one is correct? (Although none of them works :) )
float result = erf(0.5);
float result = native_erf(0.5);
float result = native_ erf(0.5);
it always return zero
Thanks a lot
Re: Fast Math
Hi, @ramin_rasoulinezhad ,
Please don't post the duplicated question.
If you think your question is related to an old post, please add the link of the old post in your new topic and refer to it.
