Visitor smhaider
Opencl Synthesis
For the following vadd.cl kernel example:
__kernel void vadd(__global const int* a, __global const int* b,__global int* c){
    int id;
   id = get_global_id(0);
   c[id] = a[id] + b[id];
UG1207 mentions OCL Region for synthesis of compute units.
If queue.enqueueNDRangeKernel is used, what is the max number of work items which can be synthesized ?
If the number of work items exceeds this count are they sequentialized ?
Maisum
Re: Opencl Synthesis
The work-item number could be very large in theory: (2^32, 2^32,2^32).
But be careful about NDRange specification. Try to make global size/local size as small as possible. Ideally, it's to set global size to (1,1,1).
brucey
brucey
Hi, @smhaider ,
Please close the thread if you don't have further question.
Hi @brucey
Did u mean that, If I have global work size as {x, y, z} then it is better to have local work size as {x, y, z} ?
Thank you
