Visitor theodort
SDAccel compilation errors
I am trying to compile one of the example projects that ship with SDAccel: SDAccel/2015.4/examples/getting_started/alpha_data
If I try running sdaccel baseline.tcl I get the following report:
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: cannot find crt1.o: No such file or directory
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: cannot find crti.o: No such file or directory
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: cannot find -lpthread
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: cannot find -lrt
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: cannot find -lm
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: cannot find -lc
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: cannot find crtn.o: No such file or directory
collect2: ld returned 1 exit status
I tried the following but with no success:
I added "set_property -name host_cflags -value "-L/usr/lib/x86_64-linux-gnu/" -objects [current_solution]" to baseline.tcl to fix the "cannot find {-lpthread,-lrt,-lm, -lc}"
and I created the following symlinks:
ln -s /usr/lib/x86_64-linux-gnu/crt1.o /usr/lib ln -s /usr/lib/x86_64-linux-gnu/crtn.o /usr/lib ln -s /usr/lib/x86_64-linux-gnu/crti.o /usr/lib to resolve the rest of the errors.
However now I'm getting a report with the following content:
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: BFD (GNU Binutils) 2.22 internal error, aborting at ../../../src/lnx64/bfd/reloc.c line 1509 in _bfd_relocate_contents
/opt/Xilinx/SDAccel/2015.4/bin/../gnu/binutils/bin/ld: Please report this bug.
and I suspect that I'm using the wrong libraries.
Target device: xilinx:adm-pcie-7v3:1ddr:2.1
OS: Debian Sid x86_64
Any suggestions?
Tags (2)
Re: SDAccel compilation errors
For crt1.o, please install glibc-devel package. On RHEL or CentOS. You will need to find the correspoinding RPM name for your Linux distribution. By the way, the officially supported linux versions are RHEL and CentOS 6.4-6.7.
sudo yum install glibc-devel
Any suggestions?
Cheers,
Jim
Any suggestions?
Cheers,
Jim
Visitor gmholland
I would try symlinking /usr/lib64/ to /usr/lib/x86_64-linux-gnu/
sudo ln -s /usr/lib/x86_64-linux-gnu /usr/lib64
I'm having this same issue.
I also happens if I source the settings64.sh file and try to compile a single file in the console.
The environment that the script sets up ends up using the gcc bundled with SDAccel but uses /usr/bin/ld for linking, instead of the ld found in the SDAccel binutils directory.
If you run strace on both linkers, you can see them looking for the lib files in different paths.
I haven't found a way to fix this satisfactorily.
bandit
Participant nachiket
Has anyone manged to figure out how to resolve this? I recently upgraded to 2016.2 and I'm seeing these same crt* related errors that were not there for 2016.1...
Resolved by adapting solution: https://forums.xilinx.com/t5/SDAccel/SDx-2016-3-Compilation-errors/td-p/739838
Instead of copying crt*.o to the Vivado_HLS folder, had to put it under /usr/lib64 instead...
This solved my problem in vivado hls 2018.2 nicely. Thanks.
