Visitor dyvala
SDAccel multi kernel build failing in synthesis
I am using SDx 2017.1_op for my own RTL kernel.
I gave Hardware Emulation build with 4 RTL kernels(all the kernels are same except the names) and it worked properly.
Using same sources when i am trying to synthesize it is throwing error.
I have attached the error message and vivado.log files.
I am using xocc command for giving builds.
Let me know, if I miss something.
Thank you in advance
Re: SDAccel multi kernel build failing in synthesis
Do a quick check and open each of the DCPs it says it can't build. If the DCP exists, verify it can build on it'w own. It might be an issue with order of operations on building the sub DCPs.
If at first you don't succeed, try redefining success?
