Observer pkuruganti
SdAccel 2017.2 + KCU1500: run 'synth_1' couldn't start because one or more of the prerequisite runs failed
I have created a KCU1500 design with 8 kernels. This design failed with cryptic error towards end of the flow (after more than 1 day of run time)
ERROR: run 'synth_1' couldn't start because one or more of the prerequisite runs failed
One or more synthesis runs failed during dynamic region dcp generation
    while executing
Spent sometime looking into logs to understand what the error is? Can someone throw light on what the issue and where to look for it? Are there any incremental flow options to rerun
I tried Emulation-HW flow and seems to have gone through as it generated all expected files in "Emulation-HW" folder, like .xclbin. .exe and system_estimate.txt files
Attached is the log from "System" run
Prasad
Observer pkuruganti
Re: SdAccel 2017.2 + KCU1500: run 'synth_1' couldn't start because one or more of the prerequisite runs failed
Ping?
hi @pkuruganti
check all the runme.log files generated during the run ; one of them has an error
maybe you run out of disk space or something more serious.
cd /workspaces/test_sdaccel/gmac_640_oct_kernel/System/
find _xocc_link_binary_container_1/ -name runme.log
should return 60+ files (that's what the log file you attached listed) ; you can pipe it to an editor for opening, for example:
find _xocc_link_binary_container_1/ -name runme.log | xargs gvim -p
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
