Synthesis takes too long time in Sdx !
Hello , i have succeeded in building xfOpenCV/example/dilation in zedboard7020 in Sdx 2018.2,which just takes few minutes ! And now i am trying to build my own project just changing from xfOpenCV/example/dilation --
#include "xf_dilation_config.h"
#pragma SDS data access_pattern("_src.data":SEQUENTIAL, "_dst.data":SEQUENTIAL)
#pragma SDS data copy("_src.data"[0:"_src.size"], "_dst.data"[0:"_dst.size"])
#pragma SDS data mem_attribute("_src.data":NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
#pragma SDS data mem_attribute("_dst.data":NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
void dilation_accel(xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> &_src,xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> &_dst)
	xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> img2;
	xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> img3;
	xf::Threshold<XF_THRESHOLD_TYPE_BINARY,XF_8UC1,HEIGHT, WIDTH,NPC1>(_src,img2,30,255,0);
	xf::dilate<XF_BORDER_CONSTANT,TYPE ,HEIGHT, WIDTH,NPC1>(img2, img3);
	xf::erode<XF_BORDER_CONSTANT,TYPE ,HEIGHT, WIDTH,NPC1>(img3,_dst);
What i have changed is just adding xf::Threshold and xf::erode to the top function , does which break the rule in using xfOpenCV ? This new project has been building from yesterday to now and the build log is like the following:
INFO: [DMAnalysis 83-4497] Analyzing callers to hardware accelerators...
Creating Vivado project and starting FPGA synthesis.
[10:24:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:25:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:26:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:27:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:28:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:29:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:30:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:31:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:32:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:33:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
[10:34:29] Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running.
I do not know what's wrong with it ! There is so many statements like " Block-level synthesis in progress, 0 of 1 jobs complete, 1 job running." and the number of these statements is going increased.
Tags (2)
Re: Synthesis takes too long time in Sdx !
has solved!
has solved!
Would you let us know your solution and mark your solution as "accept as solution"?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
@wd-hyj,
I met the same issue now.
What's the resason for your problem?
