Visitor ivars211
Vivado HLS import into SDAccel
Hello, I am trying to port c++ algorithm to VCU1525, tried using SDAccel but run into problems, as soon as I start writing more complex code, SDAccel seems to fail to compile even software emulation with the following errors (Abnormal program termination or memory fragmentation errors). Running Ubuntu 16.04.
0.	Running pass 'Array normalization' on module '/home/user/workspace/fgdsf/Emulation-SW/vadd/vadd/vadd/vadd/solution/.autopilot/db/a.o.2.bc'.
Abnormal program termination (11)
Please check '/home/user/workspace/fgdsf/Emulation-SW/vadd/vadd/vadd/hs_err_pid110829.log' for details
# An unexpected error has occurred (11)
Stack:
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f1b4b3e74b0]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libLLVM-3.1.so(llvm::ICmpInst::clone_impl() const+0x4a) [0x7f1b39494d4a]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libLLVM-3.1.so(llvm::Instruction::clone() const+0x15) [0x7f1b3948b025]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libLLVM-3.1.so(llvm::CloneBasicBlock(llvm::BasicBlock const*, llvm::ValueMap<llvm::Value const*, llvm::WeakVH, llvm::ValueMapConfig<llvm::Value const*> >&, llvm::Twine const&, llvm::Function*, llvm::ClonedCodeInfo*)+0x178) [0x7f1b399e5c08]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libLLVM-3.1.so(llvm::CloneFunctionInto(llvm::Function*, llvm::Function const*, llvm::ValueMap<llvm::Value const*, llvm::WeakVH, llvm::ValueMapConfig<llvm::Value const*> >&, bool, llvm::SmallVectorImpl<llvm::ReturnInst*>&, char const*, llvm::ClonedCodeInfo*, llvm::ValueMapTypeRemapper*)+0x44c) [0x7f1b399e737c]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_hwsyn.so(pass::ArrayNormalizeUtils::normalizeArraysAtCallSite(llvm::CallSite, bool (*)(pass::ArrayNormalizeInfo&, llvm::Function*, std::map<llvm::Function*, llvm::Function*, std::less<llvm::Function*>, std::allocator<std::pair<llvm::Function* const, llvm::Function*> > > const*), std::map<std::vector<pass::ArrayNormalizeInfo, std::allocator<pass::ArrayNormalizeInfo> >, llvm::Function*, pass::LessValueTuple, std::allocator<std::pair<std::vector<pass::ArrayNormalizeInfo, std::allocator<pass::ArrayNormalizeInfo> > const, llvm::Function*> > >&, std::map<llvm::Function*, llvm::Function*, std::less<llvm::Function*>, std::allocator<std::pair<llvm::Function* const, llvm::Function*> > >*)+0x1dc8) [0x7f1b37e43328]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_hwsyn.so(pass::ArrayNormalizeUtils::normalizeArraysBasedOnCallGraph(llvm::Function&, bool (*)(pass::ArrayNormalizeInfo&, llvm::Function*, std::map<llvm::Function*, llvm::Function*, std::less<llvm::Function*>, std::allocator<std::pair<llvm::Function* const, llvm::Function*> > > const*), std::map<llvm::Function*, llvm::Function*, std::less<llvm::Function*>, std::allocator<std::pair<llvm::Function* const, llvm::Function*> > >*)+0x12c) [0x7f1b37e43f8c]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_hwsyn.so(pass::ArraySegNormalize::runOnModule(llvm::Module&)+0x31f) [0x7f1b37e4485f]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libLLVM-3.1.so(llvm::MPPassManager::runOnModule(llvm::Module&)+0x182) [0x7f1b394b4682]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libLLVM-3.1.so(llvm::PassManagerImpl::run(llvm::Module&)+0xac) [0x7f1b394b483c]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_main.so(+0xd4779) [0x7f1b3a611779]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_support.so(xpcl::TclCommand::callback(int, Tcl_Obj* const*)+0xb6a) [0x7f1b3a30dd2a]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_support.so(+0x5505b) [0x7f1b3a30e05b]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x334af) [0x7f1b46d334af]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x76875) [0x7f1b46d76875]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x7e029) [0x7f1b46d7e029]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x76) [0x7f1b46d35156]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x1b2617) [0x7f1b4112e617]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(TclObjInterpProcCore+0x420) [0x7f1b46db7df0]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_ExprObj+0xf8) [0x7f1b46d7dc08]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_ExprBooleanObj+0x16) [0x7f1b46d33e96]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x3e6de) [0x7f1b46d3e6de]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x34b38) [0x7f1b46d34b38]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_EvalEx+0x13) [0x7f1b46d350a3]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_Eval+0x15) [0x7f1b46d350c5]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_main.so(+0x9bec2) [0x7f1b3a5d8ec2]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_support.so(xpcl::TclCommand::callback(int, Tcl_Obj* const*)+0x4dd) [0x7f1b3a30d69d]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_FSEvalFileEx+0x1da) [0x7f1b46d99c5a]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_main.so(ApSourceTclFile(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*)+0x77) [0x7f1b3a5ce437]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_main.so(+0x96339) [0x7f1b3a5d3339]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0xb7557) [0x7f1b46db7557]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x1e0) [0x7f1b46d352c0]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x3b375) [0x7f1b46d3b375]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_support.so(+0x4faa8) [0x7f1b3a308aa8]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libhls_support.so(xpcl::TclManager::tclMain(Tcl_Interp*)+0xc) [0x7f1b3a308c8c]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_hlstasks.so(+0xc18d) [0x7f1b3a9ef18d]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_common.so(+0x78e792) [0x7f1b4c6ab792]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x3cf) [0x7f1b46d354af]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0xb74a9) [0x7f1b46db74a9]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x1b26b4) [0x7f1b4112e6b4]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0xad486) [0x7f1b46dad486]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x346c5) [0x7f1b46d346c5]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x1cf84d) [0x7f1b4114b84d]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_EvalObjv+0x32) [0x7f1b46d335e2]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x322) [0x7f1b46d35402]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x200e8f) [0x7f1b4117ce8f]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x20255e) [0x7f1b4117e55e]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commonmain.so(+0x7414) [0x7f1b4bd19414]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d0) [0x7f1b46da0210]
/opt/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_common.so(+0x7d175b) [0x7f1b4c6ee75b]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7f1b44d556ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f1b4b4b941d]
 I have managed to run and hardware emulate SDAccel examples, just not my own C/C++ code. Furthermore, I can run and synthesize my own C/C++ code on Vivado HLS without any problems.
The question is, is there any way to export IP core from Vivado HLS and import it into SDAccel, so that my main C++ software can communicate to FPGA via PCIe/OpenCL like GPU accelerator? I have seen tutorials for RTL import from SDAccel, but nothing about HLS.
Re: Vivado HLS import into SDAccel
Hi, @ivars211 ,
Could you provide your code for us to reproduce the issue in SDAccel 2018.2?
