Observer jedec_001
failed to install kcu1500 driver based on 2017.2 on centos 7
  I installed 2017.2 sucessfully on centos 7, but failed to install the KCU1500 driver. Here is the error message:
   /tmp/10675/0/driver/xclng/drm/xocl/xocl_bo.c:38:2: error: too many arguments to function ‘drm_gem_object_lookup’
return drm_gem_object_lookup(dev, filp, handle);
  So how could i fix it? My os version: Linux version 3.10.0-693.21.1.el7.x86_64 (builder@kbuilder.dev.centos.org) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-16) (GCC) ) #1 SMP Wed Mar 7 19:03:37 UTC 2018.
  Another question: I installed 2017.2 and 2017.4 all in centos. Then is it possible to switch 2017.2 and 2017.4 simply by source the setting64.sh?
Re: failed to install kcu1500 driver based on 2017.2 on centos 7
Hi Jedec,
Walk me through the steps up to the error message when you try to install the driver?
Is this the driver for the board you get out of the xbinst output?
So you ran something like > sudo ./install.sh?
Evan
If at first you don't succeed, try redefining success?
Observer jedec_001
Yes, I used the command sudo ./install.sh. I installed the kcu1500 driver from 2017.2 sucessfully on Ubuntu 16. I also installed it from 2017.4 sucessfully on centos 7. I wonder if this driver from 2017.2 could be installed sucessfully on centos.
Hi Jedec,
Can you please paste the log message after you ran command "sudo ./install.sh" as Evan asked?
We need to read the log to understand what's happening.
Visitor xlmeng
Hi Moderator,
I encountered the same problem.
When I run ./install.sh with root, it failed:
# ./install.sh
INFO: Installing firmware for FPGA devices
Removing existing xclmgmt
Found hal zip..ignoring
/tmp/5222/0
Archive:  xclmgmt.zip
  inflating: driver/include/xclerr.h
  inflating: driver/include/xclbin.h
  inflating: driver/xclng/mgmt/mgmt-bit.c
  inflating: driver/xclng/mgmt/mgmt-core.c
  inflating: driver/xclng/mgmt/mgmt-core.h
  inflating: driver/xclng/mgmt/mgmt-cw.c
  inflating: driver/xclng/mgmt/mgmt-i2c.c
  inflating: driver/xclng/mgmt/mgmt-thread.c
  inflating: driver/xclng/mgmt/mgmt-firewall.c
  inflating: driver/xclng/mgmt/mgmt-utils.c
  inflating: driver/xclng/mgmt/mgmt-ioctl.c
  inflating: driver/xclng/mgmt/mgmt-xvc.c
  inflating: driver/xclng/mgmt/mgmt-sysfs.c
  inflating: driver/xclng/mgmt/xvc_pcie_ioctl.h
  inflating: driver/include/xclfeatures.h
 extracting: driver/xclng/mgmt/10-xclmgmt.rules
  inflating: driver/xclng/mgmt/Makefile
  inflating: driver/xclng/include/mgmt-reg.h
  inflating: driver/xclng/include/mgmt-ioctl.h
no makefile found in include
INFO: building kernel mode driver
make -C /lib/modules/3.10.0-693.21.1.el7.x86_64/build M=/tmp/5222/0/driver/xclng/mgmt modules
make[1]: Entering directory `/usr/src/kernels/3.10.0-693.21.1.el7.x86_64'
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-core.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-bit.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-cw.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-i2c.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-thread.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-firewall.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-utils.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-ioctl.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-xvc.o
  CC [M]  /tmp/5222/0/driver/xclng/mgmt/mgmt-sysfs.o
  LD [M]  /tmp/5222/0/driver/xclng/mgmt/xclmgmt.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /tmp/5222/0/driver/xclng/mgmt/xclmgmt.mod.o
  LD [M]  /tmp/5222/0/driver/xclng/mgmt/xclmgmt.ko
make[1]: Leaving directory `/usr/src/kernels/3.10.0-693.21.1.el7.x86_64'
INFO: Installing new kernel mode driver xclmgmt version 2017.2.1
  MODPOST 1 modules
make -C /lib/modules/3.10.0-693.21.1.el7.x86_64/build M=/tmp/5222/0/driver/xclng/mgmt modules_install
  INSTALL /tmp/5222/0/driver/xclng/mgmt/xclmgmt.ko
Can't read private key
  DEPMOD  3.10.0-693.21.1.el7.x86_64
depmod -a
install -m 644 10-xclmgmt.rules /etc/udev/rules.d
rmmod -s xclmgmt || true
modprobe xclmgmt
/tmp/5222/0
Archive:  xocl.zip
  inflating: driver/xclng/drm/xocl/libxdma.c
  inflating: driver/xclng/drm/xocl/libxdma.h
  inflating: driver/xclng/drm/xocl/xocl_bo.c
  inflating: driver/xclng/drm/xocl/xocl_drv.c
  inflating: driver/xclng/drm/xocl/xocl_sysfs.c
  inflating: driver/xclng/drm/xocl/xocl_drv.h
  inflating: driver/xclng/drm/xocl/xocl_xdma.c
  inflating: driver/xclng/drm/xocl/xocl_xdma.h
  inflating: driver/xclng/drm/xocl/cdev_sgdma.h
  inflating: driver/xclng/drm/xocl/Makefile
 extracting: driver/xclng/drm/xocl/10-xocl.rules
  inflating: driver/xclng/drm/.dir-locals.el
  inflating: driver/xclng/include/xocl_ioctl.h
  inflating: driver/xclng/include/libxdma_api.h
  inflating: driver/xclng/include/drm/drm.h
  inflating: driver/xclng/include/drm/drm_mode.h
make -C /lib/modules/3.10.0-693.21.1.el7.x86_64/build M=/tmp/5222/0/driver/xclng/drm/xocl modules
  CC [M]  /tmp/5222/0/driver/xclng/drm/xocl/xocl_sysfs.o
  CC [M]  /tmp/5222/0/driver/xclng/drm/xocl/xocl_bo.o
/tmp/5222/0/driver/xclng/drm/xocl/xocl_bo.c: In function 'xocl_gem_object_lookup':
/tmp/5222/0/driver/xclng/drm/xocl/xocl_bo.c:38:2: warning: passing argument 1 of 'drm_gem_object_lookup' from incompatible pointer type [enabled by default]
In file included from /tmp/5222/0/driver/xclng/drm/xocl/xocl_drv.h:27:0,
                 from /tmp/5222/0/driver/xclng/drm/xocl/xocl_bo.c:27:
include/drm/drm_gem.h:241:24: note: expected 'struct drm_file *' but argument is of type 'struct drm_device *'
 struct drm_gem_object *drm_gem_object_lookup(struct drm_file *filp, u32 handle);
/tmp/5222/0/driver/xclng/drm/xocl/xocl_bo.c:38:2: warning: passing argument 2 of 'drm_gem_object_lookup' makes integer from pointer without a cast [enabled by default]
include/drm/drm_gem.h:241:24: note: expected 'u32' but argument is of type 'struct drm_file *'
/tmp/5222/0/driver/xclng/drm/xocl/xocl_bo.c:38:2: error: too many arguments to function 'drm_gem_object_lookup'
include/drm/drm_gem.h:241:24: note: declared here
make[2]: *** [/tmp/5222/0/driver/xclng/drm/xocl/xocl_bo.o] Error 1
make[1]: *** [_module_/tmp/5222/0/driver/xclng/drm/xocl] Error 2
make: *** [all] Error 2
ls: cannot access *.ko: No such file or directory
INFO: Installing new kernel mode driver .ko version modinfo: ERROR: missing module or filename.
Generating SDAccel runtime environment setup script, setup.sh for bash
Generating SDAccel runtime environment setup script, setup.csh for (t)csh
Can you help to fix this problem?
