how to transfer a fixed-point with 512 bitwidth port
I have a kernel, whoes input is 10000 16 bit fixed-point data, i.e., ap_fixed<16,4>.
kernel( ap_fixed<16,4> input1,...){
To leverage the max port transfer a 512 bitwidth data should be used for kernel input.
So for  a 512 bit port, there are 512/16=32 input each read of the port.
I don't know how to write this port.
Should I write like this?
kernel( ap_fixed<512> input2,...){
And then each 16 bit of input2 will be the input1?
Re: how to transfer a fixed-point with 512 bitwidth port
Hi, @mathmaxsean ,
In host end, you have to combine the 32 16bit width data into 1 512 bit width data.
Both the data width in host and kernel are 512 bit.
Hi, @mathmaxsean ,
The interface of kernel can be any type with 512-bit width to match the DDR interface.
Then you need to split the 512-bit data to 32 16bit data by yourself.
The kernel interface can be:
 kernel( const ap_uint<512> *input2, ...){
//code for spliting the 512-bit data to 32 16-bit data by yourself
@hongh
Thanks for that.
I know the uer need to manually to splite the 512-bit data in there kernel.
For my case the type of the data is ap_fixed<16,4>
1. how can I use the 512 bit-data for the kernel port?
  Can I use ap_fixed<512> for the kernel port like the ap_uint<512>?
  Then each 16 bit is  one of my data?
2. Can I use the ap_fixed<16,4> on my host side code?
@kalib
Is there an example using the 512 fixed-point data for transfer?
Hi, @mathmaxsean ,
