Visitor mikeren
kcu1500 install fail
There are errors when I install the kcu1500.  I run the intall.sh and the result is below.
dodo-pc@dodo-PC:/opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst$ sudo ./install.sh -f yes -k yes
[sudo] dodo-pc 的密码:
INFO: Installing firmware for FPGA devices
Removing existing xclmgmt
Removing existing xocl
Found hal zip..ignoring
/tmp/2045/0
Archive:  xclmgmt.zip
  inflating: driver/include/xclerr.h
  inflating: driver/include/xclbin.h
  inflating: driver/xclng/mgmt/mgmt-bit.c
  inflating: driver/xclng/mgmt/mgmt-core.c
  inflating: driver/xclng/mgmt/mgmt-core.h
  inflating: driver/xclng/mgmt/mgmt-cw.c
  inflating: driver/xclng/mgmt/mgmt-i2c.c
  inflating: driver/xclng/mgmt/mgmt-thread.c
  inflating: driver/xclng/mgmt/mgmt-firewall.c
  inflating: driver/xclng/mgmt/mgmt-utils.c
  inflating: driver/xclng/mgmt/mgmt-ioctl.c
  inflating: driver/xclng/mgmt/mgmt-xvc.c
  inflating: driver/xclng/mgmt/mgmt-sysfs.c
  inflating: driver/xclng/mgmt/mgmt-mb.c
  inflating: driver/xclng/mgmt/xvc_pcie_ioctl.h
  inflating: driver/include/xclfeatures.h
 extracting: driver/xclng/mgmt/10-xclmgmt.rules
  inflating: driver/xclng/mgmt/Makefile
  inflating: driver/xclng/include/mgmt-reg.h
  inflating: driver/xclng/include/mgmt-ioctl.h
no makefile found in include
INFO: building kernel mode driver
make -C /lib/modules/4.8.0-36-generic/build M=/tmp/2045/0/driver/xclng/mgmt modules  #CFLAGS_MODULE=-DMGMT_1PF
make[1]: Entering directory '/usr/src/linux-headers-4.8.0-36-generic'
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-core.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-bit.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-cw.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-i2c.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-thread.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-firewall.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-utils.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-ioctl.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-xvc.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-sysfs.o
  CC [M]  /tmp/2045/0/driver/xclng/mgmt/mgmt-mb.o
  LD [M]  /tmp/2045/0/driver/xclng/mgmt/xclmgmt.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /tmp/2045/0/driver/xclng/mgmt/xclmgmt.mod.o
  LD [M]  /tmp/2045/0/driver/xclng/mgmt/xclmgmt.ko
make[1]: Leaving directory '/usr/src/linux-headers-4.8.0-36-generic'
INFO: Installing new kernel mode driver xclmgmt version 2017.4.4
  MODPOST 1 modules
make -C /lib/modules/4.8.0-36-generic/build M=/tmp/2045/0/driver/xclng/mgmt modules_install
  INSTALL /tmp/2045/0/driver/xclng/mgmt/xclmgmt.ko
At main.c:158:
- SSL error:02001002:system library:fopen:No such file or directory: bss_file.c:175
- SSL error:2006D080:BIO routines:BIO_new_file:no such file: bss_file.c:178
sign-file: certs/signing_key.pem: No such file or directory
  DEPMOD  4.8.0-36-generic
depmod -a
install -m 644 10-xclmgmt.rules /etc/udev/rules.d
rmmod -s xclmgmt || true
modprobe xclmgmt
/tmp/2045/0
Archive:  xocl.zip
  inflating: driver/xclng/drm/xocl/libxdma.c
  inflating: driver/xclng/drm/xocl/libxdma.h
  inflating: driver/xclng/drm/xocl/xocl_bo.c
  inflating: driver/xclng/drm/xocl/xocl_drv.c
  inflating: driver/xclng/drm/xocl/xocl_sysfs.c
  inflating: driver/xclng/drm/xocl/xocl_ioctl.c
  inflating: driver/xclng/drm/xocl/xocl_test.c
  inflating: driver/xclng/drm/xocl/xocl_drv.h
  inflating: driver/xclng/drm/xocl/xocl_exec.h
  inflating: driver/xclng/drm/xocl/xocl_xdma.c
  inflating: driver/xclng/drm/xocl/xocl_ctx.c
  inflating: driver/xclng/drm/xocl/xocl_xdma.h
  inflating: driver/xclng/drm/xocl/cdev_sgdma.h
  inflating: driver/xclng/drm/xocl/xocl_xvc.c
  inflating: driver/xclng/drm/xocl/xocl_xvc.h
  inflating: driver/xclng/drm/xocl/xvc_pcie_ioctl.h
  inflating: driver/xclng/drm/xocl/Makefile
 extracting: driver/xclng/drm/xocl/10-xocl.rules
  inflating: driver/xclng/drm/.dir-locals.el
  inflating: driver/xclng/include/xocl_ioctl.h
  inflating: driver/xclng/include/libxdma_api.h
  inflating: driver/xclng/include/drm/drm.h
  inflating: driver/xclng/include/drm/drm_mode.h
make -C /lib/modules/4.8.0-36-generic/build M=/tmp/2045/0/driver/xclng/drm/xocl modules
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.o
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c: In function ‘mem_topology_show’:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c:54:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
  struct drm_device *ddev = dev_get_drvdata(dev);
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c: In function ‘connectivity_show’:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c:68:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c: In function ‘ip_layout_show’:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c:81:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c: In function ‘debug_ip_layout_show’:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_sysfs.c:94:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.o
/tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.c: In function ‘xocl_free_bo’:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.c:105:23: warning: unused variable ‘xdev’ [-Wunused-variable]
  struct drm_xocl_dev *xdev = xobj->base.dev->dev_private;
/tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.c: In function ‘xocl_create_bo_ioctl’:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.c:340:23: warning: unused variable ‘xdev’ [-Wunused-variable]
  struct drm_xocl_dev *xdev = dev->dev_private;
/tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.c:337:15: warning: unused variable ‘page_count’ [-Wunused-variable]
  unsigned int page_count;
/tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.c:336:15: warning: unused variable ‘cpages’ [-Wunused-variable]
  struct page *cpages;
/tmp/2045/0/driver/xclng/drm/xocl/xocl_bo.c:334:6: warning: unused variable ‘j’ [-Wunused-variable]
  int j;
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_drv.o
In file included from ./include/linux/printk.h:6:0,
                 from ./include/linux/kernel.h:13,
                 from ./include/linux/list.h:8,
                 from ./include/linux/module.h:9,
                 from /tmp/2045/0/driver/xclng/drm/xocl/xocl_drv.c:20:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_drv.c: In function ‘probe_feature_rom’:
./include/linux/kern_levels.h:4:18: warning: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 2 has type ‘int’ [-Wformat=]
 #define KERN_SOH "\001"  /* ASCII Start Of Header */
./include/linux/kern_levels.h:13:19: note: in expansion of macro ‘KERN_SOH’
 #define KERN_INFO KERN_SOH "6" /* informational */
/tmp/2045/0/driver/xclng/drm/xocl/xocl_drv.c:122:13: note: in expansion of macro ‘KERN_INFO’
      printk(KERN_INFO "XOCL: Printing PCI VendorID: %llx\n", xdev->ddev->pdev->
/tmp/2045/0/driver/xclng/drm/xocl/xocl_drv.c:123:13: note: in expansion of macro ‘KERN_INFO’
      printk(KERN_INFO "XOCL: Printing PCI DeviceID: %llx\n", xdev->ddev->pdev->
/tmp/2045/0/driver/xclng/drm/xocl/xocl_drv.c: In function ‘xocl_init’:
/tmp/2045/0/driver/xclng/drm/xocl/xocl_drv.c:799:1: warning: label ‘unregister_pci’ defined but not used [-Wunused-label]
 unregister_pci:
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_xdma.o
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_ioctl.o
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_test.o
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_ctx.o
/tmp/2045/0/driver/xclng/drm/xocl/xocl_ctx.c:196:34: warning: ‘penguin_ops’ defined but not used [-Wunused-variable]
 static struct drm_xocl_sched_ops penguin_ops = {
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl_xvc.o
  CC [M]  /tmp/2045/0/driver/xclng/drm/xocl/libxdma.o
  LD [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl.o
  MODPOST 1 modules
  CC      /tmp/2045/0/driver/xclng/drm/xocl/xocl.mod.o
  LD [M]  /tmp/2045/0/driver/xclng/drm/xocl/xocl.ko
INFO: Installing new kernel mode driver xocl version 2017.4.5
  MODPOST 1 modules
make -C /lib/modules/4.8.0-36-generic/build M=/tmp/2045/0/driver/xclng/drm/xocl modules_install
  INSTALL /tmp/2045/0/driver/xclng/drm/xocl/xocl.ko
At main.c:158:
depmod -a
install -m 644 10-xocl.rules /etc/udev/rules.d
rmmod -s xocl || true
rmmod -s xdma || true
modprobe xocl
Generating SDAccel runtime environment setup script, setup.sh for bash
Generating SDAccel runtime environment setup script, setup.csh for (t)csh
dodo-pc@dodo-PC:/opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst$ source setup.sh
dodo-pc@dodo-PC:/opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst$ cd test/
dodo-pc@dodo-PC:/opt/dsa/xilinx_kcu1500_dynamic_5_0/xbinst/test$ ./verify.exe verify.xclbin
ERROR: Unable to open profile report for writing
Error: Failed to find an OpenCL platform!
Test failed
Visitor mikeren
Re: kcu1500 install fail
I update my bios and it works.
Scholar watari
Hi @mikeren
I guess you need to confirm "Installation Requirements" on page 8 of UG1144 (v2017.4) and install necessary package.
Would you confirm it ?
https://www.xilinx.com/support/documentation/sw_manuals_j/xilinx2017_4/ug1144-petalinux-tools-reference-guide.pdf
Best regards,
Visitor andy_fox
This one relates to the signing of the driver. It is probably benign and you may find that the driver is installed anyway.
One approach (not recommended) is to prevent Ubuntu from doing a signature check by disabling verification using: sudo mokutil --disable-validation. (Google around about that command).
I don't think the issue you report is related to your installation, I think it relates to the version of Ubuntu you are using requiring signed drivers.
PS what do you see with lspci -kvv ? Can you see the pci driver for the card ?
Observer zhengchaofeng
Hi @mikeren
    There are same failures on my kcu1500, do you have any solutions now?
Visitor njbenann
Hello @watari @andy_fox @mikeren @zhengchaofeng,
I am facing the same issue. Are there any solutions for this? Please let me know.
I used mokutil to disable verification but I still see the same issue. Stuck on this error for few weeks now. Any help will be greatly appreciated.
hello, @njbenann
In page 136 of UG1023, you can try like that.
Note: If the test directory is not write enabled, it might be necessary to run the executable from a different
directory with an absolute path to the verify.xclbin.
Visitor njbenann
Thank you for the reply @zhengchaofeng. Yes I have tried that but I still the same issue.
Since you said you have the same failures earlier, I was wondering if you have fixed it. Let me know.
Observer remy561
Same issue here with ubuntu 16.04.4 and SDAccel 2018.2. The card runs just fine though, so I guess I'll ignore it.
Hi mikeren,
   I believe you can ingore the SSL errors. They shouldn't in general affect the cards driver installs.
Verify that you can see the device:
lspci -d 10ee:
or lspci -vvv | grep Xilinx
Once you know it's there, then you should install the drivers by doing:
>sudo install.sh (generally what i do)
which will say sucess at the very end of the process. I would give it a reboot,
and then relaunch and source setup.sh
call xbsak list and see if the card is seen by xbsak.
If you can get there, then you should be good to go, otherwise please let me know where you get stopped.
If at first you don't succeed, try redefining success?
Visitor mikeren
Hi, @mikeren ,
Please close the thread as solution accepted when the issue is resolved.
