opencl kernel
Hi Guys,
I am currently working on some OpenCL development targeting Xilinx FPGA by using SDAccel at AWS F1 instance. I have few question regarding OpenCL compilation via SDAccel.
1. If I don't specify the "reqd_work_item_size" attribute with the __kernel, what is SDAccel compiler going to do? and what is the work-group size?
2. to pipeline or unroll a loop (= to use xcl_pipeline_loop or opencl_unroll_hint), does the "reqd_work_item_size" attribute should be set as {1,1,1}?
3. to pipeline work-items, does the "reqd_work_item_size" attribute should be set as {x,y,z} (where x+y+z > 1)?
4. Let assume I have a __kernel without specifying "reqd_work_item_size" attribute. If I have clEnqueueNDRangeKernel with local work size as {32, 8} in my host code, then how is this going to execute?
5. If I use "reqd_work_item_size" attribute as {x, y, z}, then what should my local work size be at clEnqueueNDRangeKernel in my host code?
Thank you
Re: opencl kernel
Hi @allien
Based on your queries related to NDRange and work group and work item structure I could emphasize that OpenCL kernel mechanism for GPUs are not directly applicable to FPGA, even if you try to enforce by specifying local and global work item/group grid for your OpenCL kernels using SDAccel it will result in compiler appending "for-loops" during opencl-hls conversion phase.
Ideal way to extract every ounce performance out of your design is to go ahead with reqd_work_group(1,1,1). This has an advantage of keeping things under control and resulting design will be scalable. To learn more about these details please have a look at the link below.
https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started
Kali
Re: opencl kernel
Hi, @allien ,
FPGA has different structure from GPU's structure and the in FPGA the work_item size is not fixed. So in FPGA, we recommend you always set NDrange to {1, ,1 ,1} to reduce overhead cost.
I don't think you need to research the other NDrange situations in FPGA design.
Re: opencl kernel
Hi @hongh
Thanks for your quick reply.
1. "the work_item size is not fixed", is it work-item or work-group ?
2. "we recommend you always set NDrange to {1, ,1 ,1}", Did you mean the local work size ?
I want to understand how the compiler is working in different scenario. I highly appreciate if you can explain me regarding the question I have posted in first post?
Thank You
Re: opencl kernel
Hi @allien
Kali
Re: opencl kernel
Hi @kalib
Thank you so much,
I think I have a starting point to optimize my code now
Re: opencl kernel
Hi @kalib,
in the following link @brucey has mentioned that "try to make global size/local size as small as possible. Ideally, it's to set global size to (1,1,1)" what does it mean?
https://forums.xilinx.com/t5/SDAccel/Opencl-Synthesis/m-p/885956/highlight/false#M2438
Thank you
Re: opencl kernel
Hi @allien
It means that in ideal scenario use (1,1,1) even though SDAccel supports basic nomenclature of OpenCL which is predominantly aligned with GPU architecture we would strongly recommend you to go with reqd_work_group_size(1,1,1) at any cost.
Please follow the same and you can also refer to our example repository that I shared in my previous answer. If you would like learn more about optimizing a real world application please look at the link below, this will provide more insights.
https://github.com/Xilinx/applications
Kali
Re: opencl kernel
Hi @kalib,
Thank You so much
