Visitor zohoraja
.xo and .xclbin reader / info
 I have few .xo/.xclbin but I could not trace its source. I tried to load it in VCU1525 and get program Info, but the program load failed.
  I would like to know about the utility which can read the xclbin and dump out all the information related to its compile environment or source.
Please help.
Thanks in Advance,
   Raja
Re: .xo and .xclbin reader / info
For xo file, just unzip it and check xml files in it.
brucey
Please try xclbinsplit command (xclbinsplit ***.xclbin) and check the xml output file.
brucey
brucey
