Adding and integrating custom third party tensorflow library to sdsoc
I am working on AI H/W acceleration on ZCU104 target board. A part of my work I want to add the custom  AI based tensorflow framework and application to sdosc and build to convert to RTL code and also needs profiling information. Could anyone suggest  me how to integrate customized Tensorflow based application to sdsoc to build .
Raghuram
Re: Adding and integrating custom third party tensorflow library to sdsoc
Hi @raghuram1a
Please refer below two documents
https://www.xilinx.com/support/documentation/user_guides/ug1327-dnndk-user-guide.pdf
https://www.xilinx.com/support/documentation/user_guides/ug1331-dnndk-sdsoc-ug.pdf
Best Regards,
Nutan
Hi Nutag,
Thanks for reply. I have gone through the document ug1331-dnndk-sdsoc. From the document page 12  i see that there is only support for caffe model is given,  with the below steps
Prerequisites
• Floating-point ResNet50 model file for Caffe ( resnet50.prototxt )
• Pre-trained weights file for ResNet50 with Caffe ( resnet50.caffemodel )
• calibration dataset
Extract 100 to 1000 images from ImageNet training dataset, and change the path in
resnet50.prototxt accordingly.
Steps
1. Convert ResNet-50 floating-point model to quantized INT8 model with the Deep Compression Tool
(DECENT).
decent
quantize
-model float.prototxt
-weights float.caffemodel
-output_dir decent_output
-method 1
Files deploy.prototxt and deploy.caffemodel are generated.
but tensorflow support and steps are not mentioned in document. I want to know the tensorflow steps .
My query is that this is dnndk integrating to sdsoc. But i want to integrate third party AI Tensorflow framework to sdsoc may I know the steps and references.
Raghuram
Hi Nutag,
Thanks for support. with out using  DNNDK tools and sdk support , I have  my own C/C++ AI based machine learning application with 3D CNN uisng tensorflow framework and want to integrate to sdosc to have H/W acceleration  and generate RTL code .  Is it possibe to integrate to sdsoc. Could you please share the steps how to proceed.
Raghuram
Hi @raghuram1a
Ok. Got it.
Please have a look at the xilinx ML suite
https://github.com/Xilinx/ml-suite
Best Regards,
Nutan
Hi Nutang,
 I have gone through ml-suite. I have found examples on caffe model. But My actual requirement is I have my own open source  trained model based on tensorflow with 2d or 3d  convolution network  along with application to provide inference so I want to this tarined model along with Application to port to sdsoc development environment to generate RTL code. Could you help me on this.
Raghuram
Hi @raghuram1a
This forum section is specific to SDSoC and reVISION.
I request you to post your question in below section.
https://forums.xilinx.com/t5/Xilinx-ML-Suite/bd-p/ML
Best Regards,
Nutan
