Observer daichong
,CHaiDNN problem
When I compile the program according to the steps described in the BUILD_USING_SDX_GUI.md file at https://github.com/Xilinx/CHaiDNN, the following error occurs. How can I solve it?
Visitor vandenplas
Re: ,CHaiDNN problem
Did you get it to build? Any tips for me?
I believe I had the same problem. Try this:
In src/design/conv/example/xi_convolution_top.cpp, change #if 0 to #if 1 on line 38
This problem occurred on my Windows machine though. When I tried running CHaiDNN on Ubuntu (note: CHaiDNN says that it's only for linux) it worked.
Does anyone have any tips for using video instead of jpg images? (Say by integrating the  'revision stack')
Observer marie-laurie
Hello @daichong !
I do not if this has been solved, I had the same problem and it was because I did not properly set up the symbole "__SDSOC" !
Hope this helps :)
ML
