CHaiDNN-v2 error: ERROR: Linking globals named 'clock_start': symbol multiply defined!
Hi guys,
Do you know why I'm having these 2 errors?
How can I solve them?
I've followed the "Creating SDx GUI Project" guide.
C:\CHaiDNN\CHaiDNN_v2\Release>exit /b 1
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'C:/Xilinx/SDx/2018.2/bin/llvm-link -o C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/sds_all.o C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/xtract/caffe.pb.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/xtract/caffe_network_parser.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/xtract/xgraph.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/xtract/xi_funcs.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/xtract/xtract_opt.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/xtract/xtract_utility.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/swkernels/xi_crop.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/swkernels/xi_fc_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/swkernels/xi_format_converter_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/swkernels/xi_nms_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/swkernels/xi_norm_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/swkernels/xi_permute_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/swkernels/xi_swsoftmax_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/scheduler/xi_perf_eval.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/scheduler/xi_scheduler.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/scheduler/xi_thread_routines.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/scheduler/xi_utils.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/interface/xi_interface.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/interface/xi_readwrite_util.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/init/xi_init.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/include/xchange_structs.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/imageread/xi_input_image.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/example/googlenet_ex.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/custom/custom_class.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/common/kernelinfo_class.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/common/xi_kernels.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/checkers/checkers.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/software/bufmgmt/xi_buf_mgmt.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/design/wrapper/dnn_wrapper.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/design/pool/src/pooling_layer_dp_2xio_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/design/deconv/src/xi_deconv_top.s C:/CHaiDNN/CHaiDNN_v2/Release/_sds/.llvm/./src/design/conv/src/xi_convolution_top.s'
 Thank you!
Re: CHaiDNN-v2 error: ERROR: Linking globals named 'clock_start': symbol multiply defined!
Hi @kardec,
We are looking into this issue. We have identified the problem and expecting it to be resolved soon.
Hi @kardec,
The issue has been fixed and pushed to master. Pull the latest from GitHub.
Thanks!
Yes, I've seen that.
I'm building the project with that modification right now, but it takes a lot of time to finish the build.
Is there any way that I can speed up the compilation process?
@kardec
You may need to run hardware builds probably on a better machine with larger RAM and faster CPU to reduce build time.
I don't think there is any other way.
Thanks!
