Visitor twlee2
Can I use the ZED camera SDK in SDx 2017.4?
I am trying to build the following example code from ZED Stereo camera in SDx 2017.4:
#include <sl_zed/Camera.hpp>
using namespace sl;
int main(int argc, char **argv) {
// Create a ZED camera object
Camera zed;
// Set configuration parameters
InitParameters init_params;
init_params.sdk_verbose = false; // Disable verbose mode
// Open the camera
ERROR_CODE err = zed.open(init_params);
if (err != SUCCESS)
exit(-1);
// Get camera information (ZED serial number)
int zed_serial = zed.getCameraInformation().serial_number;
printf("Hello! This is my serial number: %d\n", zed_serial);
// Close the camera
zed.close();
return 0;
It works fine in visual studio but when I run this code in SDx 2017.4 I get the following error:
Link application ELF file
c:/xilinx/sdk/2017.4/gnu/aarch64/nt/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/6.2.1/../../../../aarch64-linux-gnu/bin/ld.exe: cannot find -lsl_core64
c:/xilinx/sdk/2017.4/gnu/aarch64/nt/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/6.2.1/../../../../aarch64-linux-gnu/bin/ld.exe: cannot find -lsl_input64
c:/xilinx/sdk/2017.4/gnu/aarch64/nt/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/6.2.1/../../../../aarch64-linux-gnu/bin/ld.exe: cannot find -lsl_zed64
collect2.exe: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'aarch64-linux-gnu-g++ H:/Xilinx/work/zed/Release/src/main.o H:/Xilinx/work/zed/Release/_sds/swstubs/portinfo.o {-LC:\Program Files (x86)\ZED SDK\lib} {-LC:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\lib} -lsl_core64 -lsl_input64 -lsl_zed64 -L C:/Xilinx/SDx/2017.4/target/aarch64-linux/lib -LH:/Xilinx/work/zed/Release/_sds/swstubs -Wl,--start-group -Wl,--end-group -Wl,--start-group -lpthread -lsds_lib -lxlnk_stub -Wl,--end-group -o H:/Xilinx/work/zed/Release/_sds/swstubs/zed.elf'
sds++ log file saved as H:/Xilinx/work/zed/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
Can someone help me solve this issue?
Re: Can I use the ZED camera SDK in SDx 2017.4?
Hi @twlee2
The error message is pointing that the linker cannot found several libraries:
Taking a look to the linkage command used there are few paths added to it but are you sure you have the libraries available there?
Ibai
Ibai
Hi @twlee2
Ibai
Ibai
