Visitor markalbers
Customize petalinux kernel and rootfs generated from SDSOC
Hallo,
is there a possibility to customize the linux kernel and rootfs automatically generated by SDSOC? Would be nice if there was something like the config menus petalinux has got.
Mark
Re: Customize petalinux kernel and rootfs generated from SDSOC
The PetaLinux Tools offers everything necessary to customize, build and deploy Embedded Linux solutions on Xilinx processing systems. Tailored to accelerate design productivity, the solution works with the Xilinx hardware design tools to ease the development of Linux systems for Zynq-7000 All Programmable SoCs, and MicroBlaze.
The Yocto Project is an open source collaboration project that provides templates, tools and methods to help you create custom Linux-based systems for embedded products regardless of the hardware architecture. It's not an embedded Linux distribution  it creates a custom one for you!
Building the rootfs with Yocto
--------------Contents------------------
....................................System requirements
....................................Steps to follow
....................................Creating u-boot image
....................................Adding Custom packages in Yocto
....................................Creating fitimg.its and fitimg.itb files
....................................Creating fitimg.itb
....................................Booting the system with BOOT.bin and fitimg.itb
....................................PetaLinux files
....................................Yocto files
....................................Commands to boot the system
....................................Useful URLs
System requirements:
We need following utilities to be installed on the system where we are generating the image using Yocto:
  1. 1.        Mkimage
  2. DTC
Steps to follow:
Creating u-boot image:
Following steps provide information on how to create a Yocto compiled image:
  1. Clone to poky: This will create a folder named poky in current dir.
Command: git clone git://git.yoctoproject.org/poky.git
  1. Clone to meta-xilinx layer: Go into poky directory created above and then fire clone command
Commands:  cd poky
                         git clone http://github.com/Xilinx/meta-xilinx
  1. Check out a certain version:
Commands: in poky dir : git checkout -b fido origin/fido
                        cd meta-xilinx
                        cd ..
  1. Run the  setup file to create a build environment : This creates a folder named build-zc702-zynq7 in poky directory
Command: . ./oe-init-build-env build-zc702-zynq7
  1. Modify conf/bblayers.conf file and conf/local.conf file: Add the meta-xilinx layer information in the bblayers.conf file and machine information in local.conf file
  In conf/bblayers.conf : After the last value present for BBLAYERS ?= add
                /home/xilinxfae/myData/proj/zc7000/sandbox/yocto/poky/meta-xilinx \
  In conf/local.conf :  After # Machine Selection add
MACHINE ??= "zc702-zynq7"
  1. Create final image: From build-zc702-zynq7 folder, fire below command. It will create image of the format core-image-minimal****rootfs.cpio.gz.u-boot under folder tmp/deploy/images
Command:  bitbake core-image-minimal
Adding Custom packages in Yocto:
1.       If you want to add custom packages in Yocto do the following. In below example we have added smart tool:
  1. In poky dir create a layer called mylayer (meta-keyword gets attached by default to the layer name). Below command creates meta-mylayer folder in poky dir.
Command: yocto-layer -create mylayer
  1. Create dir structure recipes-core/images/ inside the meta-mylayer dir. Create one file called  myimage-image-minimal.bb inside it and add the patch of code mentioned below to the file:
Command:  Create dir structure meta-mylayer/recipes-core/images
Vim myimage-image-minimal.bb inside images folder
Add below lines to the myimage-image-minimal.bb file :
                  SUMMARY = "extended image with some extra packages"
    inherit core-image
    IMAGE_INSTALL = " packagegroup-core-boot ${ROOTFS_PKGMANAGE_BOOTSTRAP}
    ${CORE_IMAGE_EXTRA_INSTALL} "
                  CORE_IMAGE_EXTRA_INSTALL += "smartpm"
  1. For smartpm we need to download package meta-openembedded
Command: git://git.openembedded.org/meta-openembedded
  1. Add the meta-mylayer and meta-openembedded information in bblayers.conf file
    In conf/bblayers.conf file add :
/home/xilinxfae/myData/proj/zc7000/sandbox/yocto/poky/meta-mylayer \
/home/xilinxfae/myData/proj/zc7000/sandbox/yocto/poky/meta-openembedded/meta-oe \
  1. Make sure the conf/local.conf file contains the necessary machine information.
  1. Create Image by firing following command from build-zc702-zynq7 folder which will create image in the myimage-image-minimal*****rootfs.cpio.gz.u-boot format
Command:  bitbake myimage-image-minimal
Creating fitimg.its and fitimg.itb files:
Creating fitimg.its:
    Create file named fitimg.its and paste the following in the file:
* fit2015_2.its
* If you cut and paste:
* - beware of dos/linux line endings
* - watch how special characters like double quotes copy over
/dts-v1/;
description = "fit 2015.2 its";
/*timestamp = <12345678>; # Added by mkimage; do not add manually*/
#address-cells = <1>;
images {
kernel@1 {
description = "OSL 2015.2 kernel";
data = /incbin/("./zImage.gz");
type = "kernel";
arch = "arm";
os = "lin
ux";
compression = "gzip
load = <0x8000>;
entry = <0x8000>;
ramdisk@1 {
description = "OSL 2015.2 ramd
isk";
data = /incbin/("./ramdisk.image.gz");
type = "ramd
isk";
arch = "arm";
os = "lin
ux";
compression = "gzip
fdt@1 {
description = "OSL 2015.2 device tree blob";
data = /incbin/("./devicetree.dtb");
type = "flat
_dt";
arch = "arm";
compression = "none";
configurations {
default = "conf@1";
conf@1 {
description = "default configuration";
kernel = "kernel@1";
ram
disk = "ramdisk@1";
fdt = "fdt@1";
Creating fitimg.itb:
Create folder named FITImage and copy the following in the folder->
m
kdir FITImag
e
cp fitim
g.its FITimage/. /*The one we created in above step*/
cp
zImage FITimage/.   /*The one we created using peta-linux command in PetaLinux project*/
cp sys
tem.dtb FITimage/devicetree.dtb  /*From PetaLinux project*/
cp  core-image-minimal****rootfs.cpio.gz .u-bootFITimag/urootfs.cpio.gz  /*The one we
created using bitbake command*/
cd F
ITimage
gzip -9 < zImage > zImage.gz
dd if=urootfs.cpio.gz of=ramdisk.image.gz ibs=64 sk
ip=1
mkimage -f fitimg.its fitimg.itb
cp fit
img.itb  <to sdcard. For us under /mnt/sdCard1 partition>
sync
Booting the system with BOOT.bin and fitimg.itb:
PetaLinux files:
Place the BOOT.bin from the PetaLinux project in the sdcard to boot.
Yocto files:
Place the fitimg.itb created above in the sdcard.
Commands to boot the system:
Place the sdcard on board.
Halt the autoboot process
On u-boot prompt execute:  fatload mmc 0 0x3000000 fitimg.itb
 E
xectue:  bootm 0x3000000
This will boot the system with support for large files and smart support.
Useful URLs:
1.       Yocto Project Information :
https://github.com/kratsg/meta-l1calo/wiki/Building-and-Deploying-an-OS
  1. Layers and recipes information
http://layers.openembedded.org/layerindex/branch/master/layers/
System booted
Here you can see some additional packages that were added to the filesystem:
Figure 1 - Large filesystem support
Figure 2 - NFS support
Figure 3 - Package manager smart
Thanks and Regards
Balkrishan
Visitor markalbers
What I exactly mean:
I have a custom platform developed with Vivado and a Linux running on it created with Petalinux Tools. It would be very nice now, if I was able to use SDSoC to create an application with some additional automatically generated hardware. The "problem" is sticking the results from SDSoc together with my custom Linux. So I wondered if there was a possibility to tell SDSoC to generate the Linux like I told the Petalinux Tools before.
You can use your custom Vivado design and Linux to create an SDSoC platform, using the processes and tools
described in the document "SDSoC Environment User Guide: Platforms and Libraries" http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1146-sdsoc-platforms-and-libraries.pdf
An SDSoC platform includes hardware (Vivado design, XML metadata) and software (include files, libraries,
Linux kernel/filesystem/devicetree, XML metadata, etc) required to compile and link both the generated hardware
system and applications that use functions accelerated in the programmable logic (PL). The Linux you build using
PetaLinux just needs to be included as part of your custom platform's software data and SDSoC copies it into the SD card
image produced for applications built using your custom platform. The Linux included with SDSoC provided platforms are
not generated dynamically by SDSoC running PetaLinux, but are included in the form of pre-generated kernel, ramdisk
and devicetree files residing in individual platform folders in the installation.
The Linux you build does need to include kernel drivers required by SDSoC, and UG1146 provides documentation describing
how to do that.
