Observer quwei
ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing
when I use revision getting star guide 2017.2. when i want to build the optical flow sample application .
I get the error is :
make pre-build main-build
sdsoc_make_clean Release
Building file: ../src/optical_flow.cpp
Invoking: SDS++ Compiler
ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing /home/qw/sdx/test_opencv/of3/src/optical_flow.cpp
sds++ log file saved as /home/qw/sdx/test_opencv/of3/Release/_sds/reports/sds_optical_flow.log
ERROR: [SdsCompiler 83-5004] Build failed
src/subdir.mk:21: recipe for target 'src/optical_flow.o' failed
make: *** [src/optical_flow.o] Error 1
is there anyone can help me ?tanks so much
Re: ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing
hi ,
even i got the same error for every project did u got the answer,
can u please share the answer,
K S harmila
