Errors when synthesizing the HLS FFT IP in SDSoC
I want to synthesize the HLS FFT ip example in the SDSoc. Everything works fine, but it seems the software has generated some connections to the ports that do not exist. The fft_config1_34 seems to be related to the user defined configuration for the FFT core. Anyone could help? Thanks very much!
Which function is moved to hardware? And what is the data type of each argument?
This is part of the header file:QQ截图20160826093834.jpg
