Observer xx402709844
FFT in SDSoC
The FFT library works fine for HLS, but when I use the fft library in SDSoC, and there are errors about functions not define. I think the SDSoC will link to the HLS library, but something wrong with this case? Anyone could help? Thanks!
Re: FFT in SDSoC
The code is synthesized in Vivado HLS to create the accelerator core, and is also processed by SDSoC to create a modified version of the original source with a new function containing stub code used to call the accelerator. The source file is also compiled using the cross-compiler for the target processor, e.g. the Zynq Cortex-A9. The original function remains in the source file (in this case containing FFT calls), and the error you encountered occurred while compiling the source file which contains the new function and the original function.
The Vivado HLS libraries are not available for the target processor and cannot be linked in. If you can guard the FFT calls in the source files to allow Vivado HLS to process it but exclude it from SDSoC cross compiling it, you should be able to eliminate the error. For example, see the link below
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/sdsoc_doc/topics/calling-coding-guidelines/reference_c_cpp_guidelines.html
Re: FFT in SDSoC
To work around this issue, include the source file as both "source" and "test bench" in the project
Thanks and Regards
Balkrishan
Re: FFT in SDSoC
When I transfer into HLS from SDSoC, it can be synthesized. I think it is the problem that the SDSoC's compiler fails to find the corresponding .lib and .dll files of the FFT core (which are included in the HLS library). I have tried to fix it but could not link the .lib file to the compiler.
Re: FFT in SDSoC
Re: FFT in SDSoC
