How to Control GPIO on OS: Linux
I create project on SDSoc 2018.2 using platform ZCU102. I select Operating System is Linux because I use about image processing. But I want to control 4 LEDs on PL via the GPIO. I found some discussion topics about UIO and mmap. Unfortunately, none of them work properly. So, could you introduce an official example case to use GPIO on Linux easily? Thank you very much!!!
Re: How to Control GPIO on OS: Linux
Hi @sharpmddr
This below  link will help you .
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842398/Linux+GPIO+Driver
Thanks & regards
Aravind
Hi @sharpmddr
To add more in @aravindb's reply.
Please refer below link to prepare the petalinux image for SDSoC platform utility
https://www.xilinx.com/html_docs/xilinx2018_2/sdsoc_doc/linux-boot-files-bks1504034371884.html
Best Regards,
Nutan
Best Regards,
Nutan
