How to SSH to ZCU102 board?
I'm trying to SSH to ZCU102 board from my Linux desktop. I connected a USB cable from my desktop to the USB-UART port of the board. I could access the board using "gtkterm", which is a serial port emulator. I could see the following information in board's /etc/network/interfaces
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.0
network 192.168.7.0
gateway 192.168.7.1
However, if I try to ssh to board's IP address, it's not working. Can someone help me setting up SSH?
Venky
Re: How to SSH to ZCU102 board?
Hi @kodukulav
To get the Xilinx Zynq platform IP address using the Linux command line:
1. Enter ifconfig in the command line
2. Loacte the eth0 device and get the value of inet addr
3. Open an SSH connection to the platform using a terminal software
4. Enter the inet addr in the Host Name(or IP address) and click Connect/Open
5. When the terminal window opens, it will prompt for user name and password,
6. Login as user root with password root
Hope this helps
Vijoy Sunil Kumar
Product Applications Engineer
- Don't forget to reply, kudo and accept as solution
