elaine.j.lee-2
Issues on custom SDSoC platform
Hi all.  I’m new to using Xilinx tools and I’m having a very difficult time. I’m trying to create an SDSoC custom Hardware Platform (with custom IP blocks) to run application code on a zedboard. I’ve done the UG1236 Tutorial and am using UG1146. The tutorial specifically states at the beginning of the tutorial that the purpose is “… to create an SDSoC™ platform that can be used to accelerate software functions using the SDx™ Integrated Design Environment (IDE) tool“.  This is great because I can see how SDSoC works “under the hood” when you start out with only C/C++ code then select functions to “accelerate” but it is not a how to for a custom hardware platform (i.e. is the clock wizard a must?).
I have been able to generate a *.dsa file in Vivado (2017.4) with my custom IP block and it seems to have passed “validate_dsa”.
I’ve been able to open SDx 2017.4 and create a custom platform from the *.dsa file, add it to the custom repository and select it when I create an a new “SDx Project” type Application.  I’ve chosen the custom board I created, set system configuration to “standalone” and selected “Empty Application”. I then import the code from SDK 2017.4 that I used to test the Vivado design before creating the *.dsa file.
But, I’m getting the following error when I build the project:
Where:
 ERROR: [VPL 60-341] Hardware accelerator integration failed. Aborting build_system. The following log file is available for debugging 'C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/p0/_vpl/ipi/vivado.log'. Contact your local Xilinx representative and provide the log file for further assistance.
ERROR: [VPL 60-806] Failed to finish platform linker
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'C:/Xilinx/SDSoC/SDx/2017.4/bin/vpl  --iprepo C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/iprepo/repo  --iprepo C:/Xilinx/SDSoC/SDx/2017.4/data/ip/xilinx  --platform C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/system/export/system/system.xpfm  --temp_dir C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/p0  --output_dir C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/p0/vpl  --input_file C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/p0/.xsd/top.bd.tcl  --target hw   --save_temps  --kernels none --webtalk_flag SDSoC  --remote_ip_cache C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/ip_cache '
And in the “vivado.log” file it stops here:
INFO: [Common 17-83] Releasing license: Synthesis
79 Infos, 38 Warnings, 0 Critical Warnings and 0 Errors encountered.
synth_design completed successfully
synth_design: Time (s): cpu = 00:00:39 ; elapsed = 00:00:53 . Memory (MB): peak = 916.367 ; gain = 462.723
INFO: [Common 17-600] The following parameters have non-default value.
general.maxThreads
INFO: [Common 17-1381] The checkpoint 'C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/p0/_vpl/ipi/syn/syn.runs/synth_1/system_wrapper.dcp' has been generated.
INFO: [runtcl-4] Executing : report_utilization -file system_wrapper_utilization_synth.rpt -pb system_wrapper_utilization_synth.pb
report_utilization: Time (s): cpu = 00:00:00 ; elapsed = 00:00:00.039 . Memory (MB): peak = 916.367 ; gain = 0.000
INFO: [Common 17-206] Exiting Vivado at Mon May 21 22:23:54 2018...
[Mon May 21 22:23:58 2018] synth_1 finished
wait_on_run: Time (s): cpu = 00:00:00 ; elapsed = 00:01:26 . Memory (MB): peak = 651.895 ; gain = 0.000
--- DEBUG: reset_param general.maxThreads
couldn't open "C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/p0/_vpl/ipi/syn/syn.runs/synth_2/.xocc_runmsg.txt": no such file or directory
    while executing
"open $cookie_file w"
    ("foreach" body line 22)
    invoked from within
"foreach _run $runs {
      # puts "--- DEBUG: run: [get_property NAME [get_runs $_run]]"
      set run_status [get_property STATUS [get_runs $_run]]
    (procedure "check_synth_runs_status" line 6)
    invoked from within
"check_synth_runs_status $steps_log"
    (procedure "ocl_util::create_ocl_dcp" line 80)
    invoked from within
"ocl_util::create_ocl_dcp $dsa_info $utilization $config_info"
    (file "C:/SDx_2017_4/Ontonet_pass2DSAv4/platforms/empty_test_app4/Debug/_sds/p0/_vpl/ipi/ipirun.tcl" line 162)
INFO: [Common 17-206] Exiting Vivado at Mon May 21 22:23:58 2018...
The tutorial at this point looks like this:
47 Infos, 10 Warnings, 0 Critical Warnings and 0 Errors encountered.
synth_design: Time (s): cpu = 00:00:34 ; elapsed = 00:00:43 . Memory (MB): peak = 902.395 ; gain = 448.844
general.maxThreads
INFO: [Common 17-1381] The checkpoint 'C:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/emptINFO: [Common 17-1381] The checkpoint 'C:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gINFO: [runtcl-4] Executing : report_utilization -file zynq7_board_wrapper_utilization_synth.rpt -pb zynq7_board_INFO: [runtcl-4] Executing : rreport_utilization: Time (s): cpu = 00:00:00 ; elapsed = 00:00:00.039 . Memory (MB): peak = 902.395 ; gain = 0.reporINFO: [Common 17-206] Exiting Vivado at Mon May 21 16:26:38 2018...
[Mon May 21 16:26:39 2018] synth_1 finished
wait_on_run: Time (s): cpu = 00:00:00 ; elapsed = 00:02:12 . Memory (MB): peak = 573.379 ; gain = 0.000
Design is defaulting to impl run constrset: constrs_1
Design is defaulting to synth run part: xc7z020clg484-1
INFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tclINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/INFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/zynq7_board/ip/zynq7_bINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/zynq7_board/ip/zynq7_boINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_INFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/zynq7_board/ip/zynq7_boaINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zyncINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/zynq7_board/ip/zynq7_boarINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zynINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/zynq7_board/ip/zynq7_board_processing_INFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zyINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/zynq7_board/ip/zynINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zINFO: [Project 1-454] Reading design checkpoint 'c:/VivadoSDK_2017_4/ug1236_SDSoC_Tutorial/lab1_zync_tcl_gen3/platform/empty_app/Debug/_sds/p0/_vpl/ipi/syn/syn.srcs/sources_1/bd/zynq7_boarINFO: [Netlist 29-17] Analyzing 2 Unisim elements for replacement
INFO: [Netlist 29-28] Unisim Transformation completed in 0 CPU seconds
INFO: [Project 1-479] Netlist was created with Vivado 2017.4
INFO: [Device 21-403] Loading part xc7z020clg484-1
INFO: [Project 1-570] Preparing netlist for logic optimization
What am I missing? Have I not defined or mis-defined something? Sadly it’s taken me a week to get to this point.
HELP!
stephenm
Can you post the DSA file, and tag me please ill take a look
elaine.j.lee-2
Thank you for your quick response.
elaine.j.lee-2
For those of you who may be interested here is the background:
Our goal: To run an application with custom IP blocks (done in VHDL) on the Zedboard.
  1. Used Vivado 2017.4 to create a Custom IP block with VHDL as the source.
  2. Created a Vivado 2017.4 project that included the Custom IP block.   NOTE the Vivado project we used was based on Xilinx application note xapp1170 converted for 2017.4. We just substituted the FIFO block with our custom block that is a pass thru to verify everything works before installing the actual custom block.
  3. Tested design on Zedboard.
    1. Opened SDK 2017.4 from Vivado after “exporting hardware & bitstream”.
    2. Chose “hello world” template.
    3. Built, programmed FPGA, downloaded app and ran on Zedboard. Worked.
    4. Replaced “hello world” code with an axi dma example in the SDK install path, xaxidma_example_sg_poll.c.
    5. Built, programmed FPGA, downloaded app and ran on Zedboard. Worked.
  4. Followed instructions in UG1236 to:
    1. Create the DSA in Vivado 2017.4
    2. Create the software components for the platform in SDK 2017.4
    3. Create the custom platform using SDx IDE 2017.4
    4. Create SDx IDE project using the custom platform, empty application then importing the SDK 2017.4 code used to test the Vivado HW design before creating the SDSoC custom HW platform.
    5. SDx build fails.
aripod
@elaine.j.lee-2, @stephenm
Have you found the solution for this? I am facing the same exact problem.
