Visitor chinhnguyen
Open_dsa issue in Vivado
I have this error when I run step 8 in this example:
http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.4
I am using the SDSoC 2017.4 to open the dsa file on this project
open_dsa C:/XL/zcu102_es2_rv_ss/hw/zcu102_es2_rv_ss.dsa
But the error is:
ERROR: [Common 17-94] Failed to create file C:/Users/Usersname/AppData/Roaming/Xilinx/Vivado/.Xil/Vivado-200-WGC1W7C92GP32/zcu102_es2_rv_ss_2/prj/sources_1/bd/zcu102_es2_rv_ss/ip/zcu102_es2_rv_ss_vid_phy_controller_0_0/hdl/src/verilog/zcu102_es2_rv_ss_vid_phy_controller_0_0_gtwrapper_gthe4_common_wrapper.v.
Do you know why this happens? Plase give me the hints, appreciate so much
Chinh Nguyen
Re: Open_dsa issue in Vivado
you mean, in chapter 8?
this is only a blind shot but did you try to 'cd' into your working directory before issuing the command?
Visitor chinhnguyen
Thank you for your comments,
Yes in chapter 8
I tried to "cd" to working directory but the error is the same, don't know why it generate the file at C:/Users/username/AppData/Roaming/Xilinx/Vivado/.Xil/Vivado-200-WGC1W7C92GP32/zcu102_es2_rv_ss_4/prj/sources_1/bd/zcu102_es2_rv_ss/ip/zcu102_es2_rv_ss_vid_phy_controller_0_0/...
Do I need to set up the environment variables or something like that ?
Am I able to see the PS/PL configuration in case I can open this "dsa" file
Thank you
yes, appearently.
I never opened a dsa that way but the hardware design is among the generated files in SDSoC. I usually open it directly from there.
You will not be able to see the PS configuration, though...
Tags (2)
Scholar watari
Hi @chinhnguyen
It's file path limitation issue.
Would you refer the following URL ?
https://forums.xilinx.com/t5/General-Technical-Discussion/Windows-path-length-issues-any-plans-to-fix/m-p/919607#M42484
Best regards,
