Problem with SDx project on non-reVISION platform [SdsCompiler 83-5031]
hi, folks
I am new to SDx. It is failed when using xfopencv library on a non-reVISION platform according to ug1233 for non-reVISION part.
My working environment is SDX 2018.2 on WIN 10.
I create project on zcu102 platform(non-reVISION) and using opencv library in zcu102_rv_ss_2018.2 (reVISION platform pakcage).
The project settings are as below:
when I build the project I got the error log as below:
D:\SDSoC_workspace\zcu102_non_reVISION\xfopencv_test1\Release>exit /b 0
INFO: [PragmaGen 83-3231] Successfully generated tcl script: D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/vhls/w0_xf_accumulate.tcl
Moving function w0_xf_accumulate to Programmable Logic
ERROR: [SdsCompiler 83-5031] Problem detected in Vivado HLS run - unable to find solution implementation directory for w0_xf_accumulate D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/vhls/w0_xf_accumulate/solution/impl/ip. For possible causes, review D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/vhls/w0_xf_accumulate/solution/solution.log or D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/vhls/w0_xf_accumulate_vivado_hls.log.
D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/vhls/w0_xf_accumulate_vivado_hls.log (last 20 lines):
D:/SDSoC_workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include\bits/wordsize.h:36:2: error: "__WORDSIZE is not defined"
#error "__WORDSIZE is not defined"
D:/SDSoC_workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include\bits/wordsize.h:59:2: error: "Unknown __WORDSIZE detected"
#error "Unknown __WORDSIZE detected"
fatal error: too many errors emitted, stopping now [-ferror-limit=]
C preprocessor failed.
    while executing
"source D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/vhls/w0_xf_accumulate_run.tcl"
    invoked from within
"hls::main D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/vhls/w0_xf_accumulate_run.tcl -l w0_xf_accumulate_vivado_hls.log"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
INFO: [Common 17-206] Exiting vivado_hls at Thu Nov  1 17:10:45 2018...
sds++ log file saved as D:/SDSoC_workspace/zcu102_non_reVISION/xfopencv_test1/Release/_sds/reports/sds_xf_accumulate_image_accel.log
ERROR: [SdsCompiler 83-5004] Build failed
and the log in w0_xf_accumulate_vivado_hls.log as below:
In file included from D:/SDSoC_workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include\bits/wordsize.h:32:
D:/SDSoC_workspace/zcu102-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include\bits/wordsize.h:32:10: error: #include nested too deeply
#include <bits/wordsize.h>
Any suggestions are welcomed !
Re: Problem with SDx project on non-reVISION platform [SdsCompiler 83-5031]
Hi @mcggoal,
If you want to stay with non-reVISION platform, while targetting reVISION libraries, you'll want to reduce the SYSROOT you're targeting to the bare includes and libraries needed for compilation. This means you should not use the --sysroot flag and only target the -L to the lib directory. Also, on Windows, it's a good idea to reduce path length to not potentially run into odd behavior related to the character limit.
Steve
@sgrace I come back with the same error. and I have updated library -L as below:
the build log as below:
17:01:01 **** Build of configuration Release for project zcu102_rv_test1 ****
make pre-build main-build
sdsoc_make_clean Release
'Building file: ../src/xf_accumulate_image_accel.cpp'
'Invoking: SDS++ Compiler'
sds++ -Wall -O3 -I"../src" -I"C:\Users\chgma\.Xilinx\SDx\2018.2\xfopencv\include" -I"D:\SDSoC_workspace\sysroot\usr\include" -c -fmessage-length=0 -MT"src/xf_accumulate_image_accel.o" -MMD -MP -MF"src/xf_accumulate_image_accel.d" -MT"src/xf_accumulate_image_accel.o" -o "src/xf_accumulate_image_accel.o" "../src/xf_accumulate_image_accel.cpp" -sds-hw "xf::accumulate<0,1,2160,3840,1>" xf_accumulate_image_accel.cpp  -files C:/Users/chgma/.Xilinx/SDx/2018.2/xfopencv/include/imgproc/xf_accumulate_image.hpp  -clkid 1 -sds-end -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "zcu102"
Processing -sds-hw block for xf::accumulate<0,1,2160,3840,1>
Create data motion intermediate representation
D:\SDSoC_workspace\zcu102_non_reVISION\zcu102_rv_test1\Release>D:\Xilinx\SDx\2018.2\llvm-clang\win64\llvm\bin\clang.exe -I../src -IC:\Users\chgma\.Xilinx\SDx\2018.2\xfopencv\include -ID:\SDSoC_workspace\sysroot\usr\include -Wall -fmessage-length=0 -MMD -MP -D __SDSCC__ -target aarch64-linux-gnu -mcpu=cortex-a53 -O0 -g -I D:/Xilinx/SDx/2018.2/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I D:/Xilinx/Vivado/2018.2/include -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1 -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/aarch64-linux-gnu -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/backward -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include-fixed -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/libc/usr/include -std=c++11 -emit-llvm -S D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/src/xf_accumulate_image_accel.cpp -o D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/.llvm/src/xf_accumulate_image_accel.s
D:/Xilinx/Vivado/2018.2/include/ap_int_special.h:99:1: warning: 'complex' defined as a struct template here but previously declared as a class template [-Wmismatched-tags]
struct complex<ap_int<_AP_W> > {
D:/Xilinx/Vivado/2018.2/include/ap_int_special.h:71:24: note: did you mean struct here?
template<typename _Tp> class complex;
                       struct
D:/Xilinx/Vivado/2018.2/include/ap_fixed_special.h:99:1: warning: 'complex' defined as a struct template here but previously declared as a class template [-Wmismatched-tags]
struct complex<ap_fixed<_AP_W, _AP_I, _AP_Q, _AP_O, _AP_N> > {
D:/Xilinx/Vivado/2018.2/include/ap_fixed_special.h:71:24: note: did you mean struct here?
                       struct
                       struct
C:\Users\chgma\.Xilinx\SDx\2018.2\xfopencv\include\common/xf_utility.h:71:2: warning: unused label 'Extract_pixels_loop' [-Wunused-label]
        Extract_pixels_loop:
C:\Users\chgma\.Xilinx\SDx\2018.2\xfopencv\include\imgproc/xf_accumulate_image.hpp:65:8: warning: unused variable 'y' [-Wunused-variable]
                        int y;
C:\Users\chgma\.Xilinx\SDx\2018.2\xfopencv\include\imgproc/xf_accumulate_image.hpp:68:4: warning: unused label 'ProcLoop' [-Wunused-label]
                        ProcLoop:
C:\Users\chgma\.Xilinx\SDx\2018.2\xfopencv\include\imgproc/xf_accumulate_image.hpp:60:3: warning: unused label 'ColLoop' [-Wunused-label]
                ColLoop:
C:\Users\chgma\.Xilinx\SDx\2018.2\xfopencv\include\imgproc/xf_accumulate_image.hpp:55:2: warning: unused label 'RowLoop' [-Wunused-label]
        RowLoop:
D:\SDSoC_workspace\zcu102_non_reVISION\zcu102_rv_test1\Release>exit /b 0
Performing accelerator source linting for w0_xf_accumulate
Performing pragma generation
D:\SDSoC_workspace\zcu102_non_reVISION\zcu102_rv_test1\Release>D:\Xilinx\SDx\2018.2\llvm-clang\win64\llvm\bin\clang.exe -E -ID:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/src -IC:/Users/chgma/.Xilinx/SDx/2018.2/xfopencv/include -ID:/SDSoC_workspace/sysroot/usr/include -Wall -fmessage-length=0 -MMD -MP -D __SDSCC__ -m64 -D HLS_NO_XIL_FPO_LIB -I D:/Xilinx/SDx/2018.2/target/aarch64-linux/include -ID:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/src -D __SDSVHLS__ -target aarch64-linux-gnu -mcpu=cortex-a53 -O0 -g -w -I D:/Xilinx/SDx/2018.2/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I D:/Xilinx/Vivado/2018.2/include -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1 -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/aarch64-linux-gnu -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/backward -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include-fixed -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -ID:/Xilinx/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/libc/usr/include -std=c++11 D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/src/xf_accumulate_image_accel.cpp -o D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/xf_accumulate_image_accel_pp.cpp
INFO: [PragmaGen 83-3231] Successfully generated tcl script: D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/w0_xf_accumulate.tcl
ERROR: [SdsCompiler 83-5031] Problem detected in Vivado HLS run - unable to find solution implementation directory for w0_xf_accumulate D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/w0_xf_accumulate/solution/impl/ip. For possible causes, review D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/w0_xf_accumulate/solution/solution.log or D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/w0_xf_accumulate_vivado_hls.log.
D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/w0_xf_accumulate_vivado_hls.log (last 20 lines):
D:/SDSoC_workspace/sysroot/usr/include\bits/wordsize.h:36:2: error: "__WORDSIZE is not defined"
D:/SDSoC_workspace/sysroot/usr/include\bits/wordsize.h:59:2: error: "Unknown __WORDSIZE detected"
    while executing
"source D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/w0_xf_accumulate_run.tcl"
    invoked from within
"hls::main D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/vhls/w0_xf_accumulate_run.tcl -l w0_xf_accumulate_vivado_hls.log"
    invoked from within
    invoked from within
"hls_proc $argv"
INFO: [Common 17-206] Exiting vivado_hls at Fri Nov  2 17:01:14 2018...
sds++ log file saved as D:/SDSoC_workspace/zcu102_non_reVISION/zcu102_rv_test1/Release/_sds/reports/sds_xf_accumulate_image_accel.log
make: *** [src/xf_accumulate_image_accel.o] 错误 1
17:01:14 Build Finished (took 13s.71ms)
and the "sds_xf_accumulate_image_accel.log" says below fault:
In file included from D:/SDSoC_workspace/sysroot/usr/include\bits/wordsize.h:32:
D:/SDSoC_workspace/sysroot/usr/include\bits/wordsize.h:32:10: error: #include nested too deeply
Appreciated for your reply!
Hi @mcggoal
A very important note mentioned in UG1233 is,
Note: The OpenCV library is not provided by Xilinx for custom platforms. You are required to provide the library. Use the reVISION platform in order to use the OpenCV library provided by Xilinx.
Best Regards,
Nutan
Please add "-hls-target 1" to the sds++ command options. You can right click on project, C/C++ build settings->SDS++ Compiler -> Miscellaneous, and add "-hls-target 1" as other flags.
Hello, I am using SDx18.1 and working through the tutorial at "https://github.com/Xilinx/SDSoC-Tutorials/tree/master/opencv-to-xfopencv-migration-tutorial" do you have any insight as to why I would get the following error when trying to add to command options as you suggested suggested? clang.exe: error: unknown argument: '-hls-target'
The entire sds++ command options for other flags is "-c -fmessage-length=0 -MT"$@" -hls-target 1" as suggested
Voyager
Voyager
@mcggoal
One problem you seem to have (which may not have anything to do with the original problem)....
It looks like you have a circular reference of your include file (and it doesn't look like it protects itself from multiple inclusion.
Add something like
#ifndef WORDSIZE_H
#define WORDSIZE_H
// include file contents
#endif
Hope that Helps
