Problems during setup of VPSS-CSC using v4l
I use reVision stack with IMX274 sensor and SDx 2017.4 suite.
I'm trying to setup the VPSS-CSC module inside mipi_csi2_rx using the drivers available in the video_lib (in vcap_csi).
When I try to change brightness, contrast, blue/red/green gain, it has no effect on the image. It seems that the driver does not do its job correctly.
I'm not able to find a way around that by myself, can somebody provide help ?
FYI, the v4l driver for other modules (Gamma, sensor, etc.) works properly.
BTW, I need these options to setup correct colors (see https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/Setup-of-IMX274-exposure-gain-and-gamma/td-p/854104)
Alexandre
Re: Problems during setup of VPSS-CSC using v4l
Somebody to help me here ?
