SDSoC Axi Performance Monitor
I wanted to use the analysis with Axi Performance Monitor as described in the user guide ug1027 on page 77:
-apm
Insert an AXI Performance Monitor (APM) IP block to monitor all generated hardware/software interfaces. Within the SDSoC IDE, in the Debug Perspective, you can  activate the APM prior to running your application by clicking the Start button within the  Performance Counters View. For more information on the SDSoC IDE, see the SDSoC Environment User Guide: Getting Started (UG1028).
The insertion of the APM IP block was no problem, but the described Performance Counters view in Debug perspective was not available.
Re: SDSoC Axi Performance Monitor
Hi lis_
It seems its been a while since your post. Hopefully you've figured it out.
In case anybody else runs across this post, in 2015.4 in UG1027 on page 56 it says to click:
Window -> Open Perspective -> Other -> Performance Analysis
This should give you the view you're looking for.
Good luck!
