SDSoC build error when building from ubuntu terminal
Im trying to build my SDRelease project from ubuntu terminal by manually going into the SDRelease folder of my project and typing the make command but it throws up an error when run from the ubuntu terminal.
root@Ubuntu23:~/SDSoC/workspace/lab4/SDRelease# /opt/Xilinx/SDSoC/2015.2.1/bin/sdscc -Wall -O3 -I"../src" -c -fmessage-length=0 -MT"src/SDSoC_lab_design_main.o" -MMD -MP -MF"src/SDSoC_lab_design_main.d" -MT"src/SDSoC_lab_design_main.d" -o "src/SDSoC_lab_design_main.o" "../src/SDSoC_lab_design_main.c" -sds-hw sharpen_filter sharpen.c -clkid 3 -sds-end -sds-hw sobel_filter edge_detect.c -clkid 3 -sds-end -target-os standalone -sds-pf zed
child process exited abnormally
while executing
"exec which [apc_get_global APCC_TOOLCHAIN_LINUX]-g++"
invoked from within
"file normalize [exec which [apc_get_global APCC_TOOLCHAIN_LINUX]-g++]"
invoked from within
"apc_set_global APCC_PATH_GPP_LINUX [file normalize [exec which [apc_get_global APCC_TOOLCHAIN_LINUX]-g++]]"
(file "/opt/Xilinx/SDSoC/2015.2.1/bin/xdcc.tcl" line 368)
When I run it in the SDSoC GUI window the project builds perfectly
Try sourcing the settings64.[csh|sh] script in the SDSoC installation before executing make. This script will setup your environment for running outside the GUI.
In your case:
> source /opt/Xilinx/SDSoC/2015.2.1/settings64.sh
This solution actually worked for me, thanks a lot.
