Observer adrian.n
SDx 2018.2 failed to create application project
I just installed SDx 2018.2_0614_1954 on Windows 7 SP1 64-bit.
If I go through the following tutorial, I never get to the System Configuration window or the Template window: https://github.com/Xilinx/SDSoC-Tutorials/blob/master/getting-started-tutorial/lab-1-introduction-to-the-sdsoc-development-environment.md
SDx seems to stay on the Platform window, and then when I click Finish, I get the message "Failed to create application project. See SDx log for details. The logfile is pasted below.
This seems like a broken installation to me. I did uninstall a previous version of Vivado before I installed SDx 2018.2. However, even after installing and re-installing SDx, it still is not fixed.
logfile:
19:45:07 INFO  : Launching XSCT server: xsct.bat -n -sdx -interactive C:\Users\HEP\Desktop\sdx_wkspc\temp_xsdb_launch_script.tcl
19:45:08 INFO  : Registering command handlers for SDx TCF services
19:45:08 INFO  : Registering command handlers for SDK TCF services
19:45:18 INFO  : Validating SDSoC License...
19:45:18 INFO  : License for SDSoC is unavailable
19:45:18 INFO  : Validating SDAccel License...
19:45:18 INFO  : License available for SDAccel
19:45:23 INFO  : XSCT server has started successfully.
19:45:29 INFO  : plnx-install-location is set to ''
19:45:29 INFO  : Successfully done setting XSCT server connection channel
19:45:29 INFO  : Successfully done setting SDK workspace
19:45:55 ERROR : Failed to create application project
java.lang.NullPointerException
    at com.xilinx.sdsoc.ui.project.SDXProjectCreationHandler.<init>(SDXProjectCreationHandler.java:64)
    at com.xilinx.sdx.npw.SDXApplicationCreationHandler.createApplicationProject(SDXApplicationCreationHandler.java:144)
    at com.xilinx.sdx.npw.SDXApplicationCreationHandler.internalExecute(SDXApplicationCreationHandler.java:244)
    at com.xilinx.sdx.npw.SDXApplicationCreationHandler.access$0(SDXApplicationCreationHandler.java:225)
    at com.xilinx.sdx.npw.SDXApplicationCreationHandler$1.execute(SDXApplicationCreationHandler.java:72)
    at org.eclipse.ui.actions.WorkspaceModifyOperation.lambda$0(WorkspaceModifyOperation.java:107)
    at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
    at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
    at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:128)
    at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Observer adrian.n
Re: SDx 2018.2 failed to create application project
It seems like this was an issue with SDx not finding the SDAccel license (see: https://forums.xilinx.com/t5/SDAccel/SDx-missing-templates-screenshot/m-p/876518/highlight/true#M2305). After I refreshed my license server, I was able to progress to the Template window.
Visitor wuzer57
The SDAccel™ Development Environment can only  run on Linux operating systems
