Observer kdavis119
SDx Platform vs Application
Do you have to create a SDSOC platform prior to creating an application ? Or, can I target the zcu102 option for the application project without going through the process of platform creation ?
Re: SDx Platform vs Application
@kdavis119 If you are targetting the ZCU102 board then select the ZCU102 platform provided by Xilinx. You would see the option to select the platform right after you name your project.
If you want to target a board for which Xilinx hasn't provided a platform, you need to create the platform.
Observer kdavis119
@khareashish_trimble Does AR#71961 require a rebuild of the FSBL and therefore a rebuild of the project, negating the use of the Xilinx provided zcu102 platform however ?
 @kdavis119
Which SDSoC version you are using?
Best Regards,
Nutan
Observer kdavis119
@nutang
I am using version 2018.3
Hi @kdavis119
Ok. If your evaluation board comes under the affected serial numbers. there is a chance that existing platform might not work, but I am not sure.
Did you try with the existing zcu102 platform first?
Best Regards,
Nutan
Observer kdavis119
@nutang
Yes, I have tried under the existing platform first.  The board seems to be able to boot and execute .elfs, though we ocassionally have to do a quick power off power on cycle or the INIT_B LED will stay red.  What is the behavior expected for boards that need a new FSBL ? Will they simply not boot at all ?
Hi @kdavis119
The behaviour was like, people who have affected boards, when they run hello world example in xilinx SDK, it did not work.
some people reported "execution context is running " error. Few said, it just didn't run.
In case of SDSoC, when they ran matrix multiplaication example, it didn't work
https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/SDSoC-ZCU102-execution-context-is-running-error/m-p/964868
Best Regards,
Nutan
