Observer sleach3
SDx Revision Filter2D example won't build out of box
I was attempting to build the revision filter2D example just to work through the process. I am using SDSoC 2018.3 on Linux Mint. However, when after I finish building the filter2D project and I go to build the gst-- projects I get following error in the gstsdxfilter2d project:
aarch64-linux-gnu-g++ -Wall -O0 -g3 -I/home/sleach3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux//usr/include -I/home/sleach3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux//usr/include/glib-2.0 -I/home/sleach3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux//usr/lib/glib-2.0/include -I/home/sleach3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux//usr/include/gstreamer-1.0 -I/home/sleach3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux//usr/lib/gstreamer-1.0/include -c -fPIC -fpermissive -fmessage-length=0 -MT"filter2d_cv.o" --sysroot=/home/sleach3/zcu104-rv-ss-2018-3/zcu104_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/ -MMD -MP -MF"filter2d_cv.d" -MT"filter2d_cv.o" -o "filter2d_cv.o" "../filter2d_cv.cpp"
../filter2d_cv.cpp:40:10: fatal error: filter2d_sds.h: No such file or directory
 #include <filter2d_sds.h>
compilation terminated.
subdir.mk:21: recipe for target 'filter2d_cv.o' failed
make: *** [filter2d_cv.o] Error 1
I was following the tutorial from this link: https://github.com/Xilinx/reVISION-Getting-Started-Guide/blob/master/Docs/tool-flow-tutorials.md
This appears to be a linking issue as the projects are unable to see eachother's files but I am unsure of how to fix the problem.
Re: SDx Revision Filter2D example won't build out of box
Hi @sleach3
Have you set the SYSROOT?
If yes, please share the whole log
Best Regards,
Nutan
Hi @sleach3
Please share the screenshot of C/C++ build settings -> C/C++ general -> paths and symbols
Best Regards,
Nutan
Observer sleach3
Hey @nutang ,
Thank you for your quick response. I actually discovered last night that the issue was when I did the step to create the "filter2d" project, I actually named my project "filter2D" with a capital D and therefore the system was unable to find the filter2d_sds.h file. Once I fixed that issue everything worked fine!
