The issues of 2018.3 Development environment issues
I have a Lenet5 handwriting recognition program. There is no problem in the SDx 2018.2 environment. When I upgraded to the SDx 2018.3 environment, I have the following problems. I don't think this problem should be a problem with my program. Please help me answer it. What do I need to do to make the program compile and pass.
sds++ -Wall -O0 -g -I"../src" -c -fmessage-length=0 -MT"src/lenet5/hw_layers/image_convolution.o" -MMD -MP -MF"src/lenet5/hw_layers/image_convolution.d" -MT"src/lenet5/hw_layers/image_convolution.o" -o "src/lenet5/hw_layers/image_convolution.o" "../src/lenet5/hw_layers/image_convolution.cpp" -sds-hw CONVOLUTION_LAYER_1 image_convolution.cpp -clkid 1 -sds-end -sds-hw CONVOLUTION_LAYER_2 image_convolution.cpp -clkid 1 -sds-end -sds-hw CONVOLUTION_LAYER_3 image_convolution.cpp -clkid 1 -sds-end -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "zcu102"
Processing -sds-hw block for CONVOLUTION_LAYER_1
Processing -sds-hw block for CONVOLUTION_LAYER_2
Processing -sds-hw block for CONVOLUTION_LAYER_3
Analyzing source for RTL template usage
C:/Xilinx/Vivado/2018.3/include\ap_common.h:645:61: error: expected ')'
inline _Tp1 _AP_ROOT_op_concat(const _Tp1& Ret, const _Tp2& X, const _Tp3& Y) {
D:\lenet5HW\test\src\lenet5\hw_layers/../common.h:57:11: note: expanded from macro 'X'
#define X 0
C:/Xilinx/Vivado/2018.3/include\ap_common.h:645:31: note: to match this '('
C:/Xilinx/Vivado/2018.3/include\ap_common.h:646:15: error: member reference base type 'int' is not a structure or union
_Tp1 r = (X).operator,(Y);
C:/Xilinx/Vivado/2018.3/include\ap_common.h:646:26: error: use of undeclared identifier 'Y'
Error while processing D:\lenet5HW\test\src\lenet5\hw_layers\image_convolution.cpp.
ERROR: [TemplateExtract 83-3509] Failed to run clang frontend action of rtl_template_extract!
ERROR: [SdsCompiler 83-5176] RTL template analysis exited with non-zero code processing D:/lenet5HW/test/src/lenet5/hw_layers/image_convolution.cpp
sds++ log file saved as D:/lenet5HW/test/Debug/_sds/reports/sds_image_convolution.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [src/lenet5/hw_layers/subdir.mk:20: src/lenet5/hw_layers/image_convolution.o] Error 1
11:04:41 Build Finished (took 10s.518ms)
