Visitor dprze
XfOpencv - Sobel Live I/O 8NPPC problem
I am trying to perform Sobel (from xfOpencv) on live input stream, processing 8 pixels per clock cycle, as it is possible according to documentation. Earlier I have succesfully ran Sobel with 1NPPC on live I/O.
I have modified code for reading input and writing output as follows:
#ifndef NUM_OF_PIXEL_PER_CLOCK
#define NUM_OF_PIXEL_PER_CLOCK XF_NPPC8
#endif
#pragma SDS data mem_attribute("inoutUV.data":NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
#pragma SDS data mem_attribute(frm_data_in:NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
#pragma SDS data copy("inoutUV.data"[0:"inoutUV.size"])
#if (NUM_OF_PIXEL_PER_CLOCK == XF_NPPC1)
#pragma SDS data copy(frm_data_in[0:pcnt])
#else //NUM_OF_PIXEL_PER_CLOCK == XF_NPPC8
#pragma SDS data copy(frm_data_in[0:pcnt>>3])
#endif
#pragma SDS data access_pattern("inoutUV.data":SEQUENTIAL)
#pragma SDS data access_pattern(frm_data_in:SEQUENTIAL)
#pragma SDS data mem_attribute("inLuma.data":NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
#pragma SDS data copy("inLuma.data"[0:"inLuma.size"])
#pragma SDS data access_pattern("inLuma.data":SEQUENTIAL)
void read_input(XF_TNAME(XF_16UC1, NUM_OF_PIXEL_PER_CLOCK) *frm_data_in,
		    xf::Mat<XF_8UC1, HEIGHT, WIDTH, NUM_OF_PIXEL_PER_CLOCK> &inLuma,
		    xf::Mat<XF_8UC1, HEIGHT, WIDTH, NUM_OF_PIXEL_PER_CLOCK> &inoutUV,
		    uint32_t in_fourcc, int pcnt)
	unsigned short lumamask    = (V4L2_PIX_FMT_YUYV==in_fourcc)? 0x00FF : 0xFF00;
	unsigned short lumashift   = (V4L2_PIX_FMT_YUYV==in_fourcc)? 0      : 8;
	unsigned short chromamask  = (V4L2_PIX_FMT_YUYV==in_fourcc)? 0xFF00 : 0x00FF;
	unsigned short chromashift = (V4L2_PIX_FMT_YUYV==in_fourcc)? 8      : 0;
	for(int i=0; i<pcnt; i++){
#pragma HLS pipeline II=1
		unsigned short yuvpix = frm_data_in[i];
		ap_uint<8> ypix =  (ap_uint<8>)((yuvpix & lumamask)>>lumashift);
		ap_uint<8> uvpix = (ap_uint<8>)((yuvpix & chromamask)>>chromashift);
		inLuma.data[i] = ypix;
		inoutUV.data[i] = uvpix;
	ap_uint<128> lumamask_8 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x00FF0000000000000000000000000000 : 0xFF000000000000000000000000000000;
	ap_uint<16>	lumashift_8 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 56 : 64;
	ap_uint<128> lumamask_7 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x000000FF000000000000000000000000 : 0x0000FF00000000000000000000000000;
	ap_uint<16>	lumashift_7 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 48 : 56;
	ap_uint<128> lumamask_6 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x0000000000FF00000000000000000000 : 0x00000000FF0000000000000000000000;
	ap_uint<16>	lumashift_6 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 40 : 48;
	ap_uint<128> lumamask_5 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x00000000000000FF0000000000000000 : 0x000000000000FF000000000000000000;
	ap_uint<16>	lumashift_5 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 32 : 40;
	ap_uint<128> lumamask_4 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x000000000000000000FF000000000000 : 0x0000000000000000FF00000000000000;
	ap_uint<16>	lumashift_4 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 24 : 32;
	ap_uint<128> lumamask_3 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x0000000000000000000000FF00000000 : 0x00000000000000000000FF0000000000;
	ap_uint<16>	lumashift_3 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 16 : 24;
	ap_uint<128> lumamask_2 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x00000000000000000000000000FF0000 : 0x000000000000000000000000FF000000;
	ap_uint<16>	lumashift_2 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 8 : 16;
	ap_uint<128> lumamask_1 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x000000000000000000000000000000FF : 0x0000000000000000000000000000FF00;
	ap_uint<16>	lumashift_1 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0 : 8;
	ap_uint<128> chromamask_8 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0xFF000000000000000000000000000000 : 0x00FF0000000000000000000000000000;
	ap_uint<16>	chromashift_8 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 64 : 56;
	ap_uint<128> chromamask_7 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x0000FF00000000000000000000000000 : 0x000000FF000000000000000000000000;
	ap_uint<16>	chromashift_7 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 56 : 48;
	ap_uint<128> chromamask_6 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x00000000FF0000000000000000000000 : 0x0000000000FF00000000000000000000;
	ap_uint<16>	chromashift_6 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 48 : 40;
	ap_uint<128> chromamask_5 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x000000000000FF000000000000000000 : 0x00000000000000FF0000000000000000;
	ap_uint<16>	chromashift_5 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 40 : 32;
	ap_uint<128> chromamask_4 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x0000000000000000FF00000000000000 : 0x000000000000000000FF000000000000;
	ap_uint<16>	chromashift_4 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 32 : 24;
	ap_uint<128> chromamask_3 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x00000000000000000000FF0000000000 : 0x0000000000000000000000FF00000000;
	ap_uint<16>	chromashift_3 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 24 : 16;
	ap_uint<128> chromamask_2 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x000000000000000000000000FF000000 : 0x00000000000000000000000000FF0000;
	ap_uint<16>	chromashift_2 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 16 : 8;
	ap_uint<128> chromamask_1 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 0x0000000000000000000000000000FF00 : 0x000000000000000000000000000000FF;
	ap_uint<16>	chromashift_1 = (V4L2_PIX_FMT_YUYV==in_fourcc) ? 8 : 0;
	for(int i=0; i<pcnt>>3; i++){
			ap_uint<128> yuvpix = frm_data_in[i];
			ap_uint<64> ypix =  (ap_uint<64>)((yuvpix & lumamask_8)>>lumashift_8) |
								(ap_uint<64>)((yuvpix & lumamask_7)>>lumashift_7) |
								(ap_uint<64>)((yuvpix & lumamask_6)>>lumashift_6) |
								(ap_uint<64>)((yuvpix & lumamask_5)>>lumashift_5) |
								(ap_uint<64>)((yuvpix & lumamask_4)>>lumashift_4) |
								(ap_uint<64>)((yuvpix & lumamask_3)>>lumashift_3) |
								(ap_uint<64>)((yuvpix & lumamask_2)>>lumashift_2) |
								(ap_uint<64>)((yuvpix & lumamask_1)>>lumashift_1);
			ap_uint<64> uvpix =	(ap_uint<64>)((yuvpix & chromamask_8)>>chromashift_8) |
								(ap_uint<64>)((yuvpix & chromamask_7)>>chromashift_7) |
								(ap_uint<64>)((yuvpix & chromamask_6)>>chromashift_6) |
								(ap_uint<64>)((yuvpix & chromamask_5)>>chromashift_5) |
								(ap_uint<64>)((yuvpix & chromamask_4)>>chromashift_4) |
								(ap_uint<64>)((yuvpix & chromamask_3)>>chromashift_3) |
								(ap_uint<64>)((yuvpix & chromamask_2)>>chromashift_2) |
								(ap_uint<64>)((yuvpix & chromamask_1)>>chromashift_1);
#endif
#pragma SDS data mem_attribute("outLuma.data":NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
#pragma SDS data copy("outLuma.data"[0:"outLuma.size"])
#pragma SDS data access_pattern("outLuma.data":SEQUENTIAL)
#pragma SDS data mem_attribute(frm_data_out:NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
#pragma SDS data copy(frm_data_out[0:pcnt])
#pragma SDS data copy(frm_data_out[0:pcnt>>3])
#endif
#pragma SDS data access_pattern(frm_data_out:SEQUENTIAL)
void write_output(xf::Mat<XF_8UC1, HEIGHT, WIDTH, NUM_OF_PIXEL_PER_CLOCK> &outLuma,
			  XF_TNAME(XF_16UC1, NUM_OF_PIXEL_PER_CLOCK) *frm_data_out, uint32_t out_fourcc, int pcnt)
	unsigned short lumashift = (V4L2_PIX_FMT_YUYV==out_fourcc)? 0 : 8;
	unsigned short chromashift = (V4L2_PIX_FMT_YUYV==out_fourcc)? 8 : 0;
		ap_uint<8> ypix = outLuma.data[i];
		ap_uint<8> uvpix = inoutUV.data[i];
		unsigned short yuvpix = ((unsigned short) uvpix << chromashift) | ((unsigned short) ypix << lumashift);
		frm_data_out[i] = yuvpix;
	unsigned short lumashift_8 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 56 : 64;
	unsigned short lumashift_7 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 48 : 56;
	unsigned short lumashift_6 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 40 : 48;
	unsigned short lumashift_5 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 32 : 40;
	unsigned short lumashift_4 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 24 : 32;
	unsigned short lumashift_3 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 16 : 24;
	unsigned short lumashift_2 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 8 : 16;
	unsigned short lumashift_1 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 0 : 8;
	unsigned short chromashift_8 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 64 : 56;
	unsigned short chromashift_7 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 56 : 48;
	unsigned short chromashift_6 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 48 : 40;
	unsigned short chromashift_5 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 40 : 32;
	unsigned short chromashift_4 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 32 : 24;
	unsigned short chromashift_3 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 24 : 16;
	unsigned short chromashift_2 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 16 : 8;
	unsigned short chromashift_1 = (V4L2_PIX_FMT_YUYV==out_fourcc)? 8 : 0;
			ap_uint<64> ypix = outLuma.data[i];
			ap_uint<64> uvpix = inoutUV.data[i];
			ap_uint<64> yuvpix_8 = ((ap_uint<64>) uvpix << chromashift_8) | ((ap_uint<64>) ypix << lumashift_8);
			ap_uint<64> yuvpix_7 = ((ap_uint<64>) uvpix << chromashift_7) | ((ap_uint<64>) ypix << lumashift_7);
			ap_uint<64> yuvpix_6 = ((ap_uint<64>) uvpix << chromashift_6) | ((ap_uint<64>) ypix << lumashift_6);
			ap_uint<64> yuvpix_5 = ((ap_uint<64>) uvpix << chromashift_5) | ((ap_uint<64>) ypix << lumashift_5);
			ap_uint<64> yuvpix_4 = ((ap_uint<64>) uvpix << chromashift_4) | ((ap_uint<64>) ypix << lumashift_4);
			ap_uint<64> yuvpix_3 = ((ap_uint<64>) uvpix << chromashift_3) | ((ap_uint<64>) ypix << lumashift_8);
			ap_uint<64> yuvpix_2 = ((ap_uint<64>) uvpix << chromashift_2) | ((ap_uint<64>) ypix << lumashift_2);
			ap_uint<64> yuvpix_1 = ((ap_uint<64>) uvpix << chromashift_1) | ((ap_uint<64>) ypix << lumashift_1);
			frm_data_out[i] = 	yuvpix_8 | yuvpix_7 | yuvpix_6 | yuvpix_5 |
								yuvpix_4 | yuvpix_3 | yuvpix_2 | yuvpix_1;
#endif
I am calling Sobel as follows:
xf::Sobel<XF_BORDER_CONSTANT, 3, XF_8UC1, XF_8UC1,HEIGHT, WIDTH, NUM_OF_PIXEL_PER_CLOCK>(*image->inLuma, *image->SobelX, *image->SobelY);
These are all code changes in comparision to 1NPPC processing and this solution does not work, and frankly I have no idea why - the image from before starting Sobel is frozen on output screen.
If it makes any difference, I am processing 4K image.
I am working on ZCU102 platform, SDx 2017.4.
I would appreciate your help,
best regards!
Visitor vandenplas
Re: XfOpencv - Sobel Live I/O 8NPPC problem
Could you help me get the same think working on my ZCU102 board
I've tried to compile the revision example, but it just comes up with a  M_AXI_GP port error.
My plan is to be able to grab image frames from a camera and put a rectangle around any object
hi @dprze :
XF_8UC1 : the bit number of pixel is 8
so
is not correct
by miter
