a70024
can't include arm_neon.h for aarch64 correctly.
Dear Xilinx:
  I am migrating eigen library to ZCU102, but there are lots of build errors about can't find type declartions of
__Int8x8_t
_Int16x4_t
__Int32x2_t
...so on.
they are caused simply by including the file, arm_neon.h.
/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h
would you let me know how do I get these defines from SDSoc tool chain?
[log]
/home/lucas/Project/Software/SDSoc_2017-4/SDx/2017.4/bin/clang_wrapper -I../../ -I../src -Wall -g -fmessage-length=0 -MMD -MP -D __SDSCC__ -target aarch64-linux-gnu -mcpu=cortex-a53 -O0 -g -I /home/lucas/Project/Software/SDSoc_2017-4/SDx/2017.4/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I /home/lucas/Project/Software/SDSoc_2017-4/Vivado/2017.4/include -I/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -I/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -I/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -I/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -I/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -I/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include -I/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include -std=c++11 -emit-llvm -S /home/lucas/Project/git_workspace/eigen-git-mirror/project/gemm_test/src/main.cpp -o /home/lucas/Project/git_workspace/eigen-git-mirror/project/gemm_test/Debug/_sds/.llvm/src/main.s
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:30:13: warning: unknown pragma ignored [-Wunknown-pragmas]
#pragma GCC push_options
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:31:13: warning: unknown pragma ignored [-Wunknown-pragmas]
#pragma GCC target ("+nothing+simd")
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:38:9: error: unknown type name '__Int8x8_t'
typedef __Int8x8_t int8x8_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:39:9: error: unknown type name '__Int16x4_t'
typedef __Int16x4_t int16x4_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:40:9: error: unknown type name '__Int32x2_t'; did you mean '__int32_t'?
typedef __Int32x2_t int32x2_t;
__int32_t
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:40:20: note: '__int32_t' declared here
typedef signed int __int32_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:41:9: error: unknown type name '__Int64x1_t'; did you mean '__int64_t'?
typedef __Int64x1_t int64x1_t;
__int64_t
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:43:25: note: '__int64_t' declared here
typedef signed long int __int64_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:42:9: error: unknown type name '__Float16x4_t'
typedef __Float16x4_t float16x4_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:43:9: error: unknown type name '__Float32x2_t'
typedef __Float32x2_t float32x2_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:44:9: error: unknown type name '__Poly8x8_t'
typedef __Poly8x8_t poly8x8_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:45:9: error: unknown type name '__Poly16x4_t'
typedef __Poly16x4_t poly16x4_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:46:9: error: unknown type name '__Uint8x8_t'
typedef __Uint8x8_t uint8x8_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:47:9: error: unknown type name '__Uint16x4_t'
typedef __Uint16x4_t uint16x4_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:48:9: error: unknown type name '__Uint32x2_t'
typedef __Uint32x2_t uint32x2_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:49:9: error: unknown type name '__Float64x1_t'
typedef __Float64x1_t float64x1_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:50:9: error: unknown type name '__Uint64x1_t'
typedef __Uint64x1_t uint64x1_t;
/home/lucas/Project/Software/SDSoc_2017-4/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include/arm_neon.h:51:9: error: unknown type name '__Int8x16_t'; did you mean '__int16_t'?
typedef __Int8x16_t int8x16_t;
BRs
CJ
liyang53719
i have the same problem in SDX 2018.2 with ZCU102.
do you have any idera?
10:34:03 **** Build of configuration Debug for project vins_mono ****
make pre-build main-build
sdsoc_make_clean Debug
Building file: ../src/utility/CameraPoseVisualization.cpp
Invoking: SDS++ Compiler
sds++ -Wall -O0 -g -I"../src" -c -fmessage-length=0 -MT"src/utility/CameraPoseVisualization.o" -MMD -MP -MF"src/utility/CameraPoseVisualization.d" -MT"src/utility/CameraPoseVisualization.o" -o "src/utility/CameraPoseVisualization.o" "../src/utility/CameraPoseVisualization.cpp" -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "zcu102"
Create data motion intermediate representation
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:30:13: warning: unknown pragma ignored [-Wunknown-pragmas]
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:31:13: warning: unknown pragma ignored [-Wunknown-pragmas]
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:38:9: error: unknown type name '__Int8x8_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:39:9: error: unknown type name '__Int16x4_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:40:9: error: unknown type name '__Int32x2_t'; did you mean '__int32_t'?
__int32_t
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:40:20: note: '__int32_t' declared here
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:41:9: error: unknown type name '__Int64x1_t'; did you mean '__int64_t'?
__int64_t
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:43:25: note: '__int64_t' declared here
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:42:9: error: unknown type name '__Float16x4_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:43:9: error: unknown type name '__Float32x2_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:44:9: error: unknown type name '__Poly8x8_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:45:9: error: unknown type name '__Poly16x4_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:46:9: error: unknown type name '__Uint8x8_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:47:9: error: unknown type name '__Uint16x4_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:48:9: error: unknown type name '__Uint32x2_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:49:9: error: unknown type name '__Float64x1_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:50:9: error: unknown type name '__Uint64x1_t'
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:51:9: error: unknown type name '__Int8x16_t'; did you mean '__int16_t'?
__int16_t
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/bits/types.h:38:26: note: '__int16_t' declared here
typedef signed short int __int16_t;
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:52:9: error: unknown type name '__Int16x8_t'
typedef __Int16x8_t int16x8_t;
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:53:9: error: unknown type name '__Int32x4_t'; did you mean '__int32_t'?
typedef __Int32x4_t int32x4_t;
__int32_t
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:54:9: error: unknown type name '__Int64x2_t'; did you mean '__int64_t'?
typedef __Int64x2_t int64x2_t;
__int64_t
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:55:9: error: unknown type name '__Float16x8_t'
typedef __Float16x8_t float16x8_t;
/home/liyang/soft/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:56:9: error: unknown type name '__Float32x4_t'
typedef __Float32x4_t float32x4_t;
fatal error: too many errors emitted, stopping now [-ferror-limit=]
ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing /home/liyang/workspace/vins_mono/src/utility/CameraPoseVisualization.cpp
sds++ log file saved as /home/liyang/workspace/vins_mono/Debug/_sds/reports/sds_CameraPoseVisualization.log
ERROR: [SdsCompiler 83-5004] Build failed
src/utility/subdir.mk:24: recipe for target 'src/utility/CameraPoseVisualization.o' failed
make: *** [src/utility/CameraPoseVisualization.o] Error 1
10:34:05 Build Finished (took 2s.17ms)
sgrace
In your code, you'd need to gate the ARM_NEON from being used in compilation.
You would need to do something like this (from the OpenCV to xfOpenCV tutorial):
#if __SDSCC__
#undef __ARM_NEON__
#undef __ARM_NEON
#include "opencv2/highgui/highgui.hpp"
#include "opencv2/imgproc/imgproc.hpp"
#include <opencv2/core/core.hpp>
#define __ARM_NEON__
#define __ARM_NEON
#else
#endif
The includes would be related to any image processing you're doing.
Hope this helps.
Steve
kardec
did you solve the problem?
I'm having the same problem when building another project (CHaiDNN)
xiaohong_liut
It doesn't work for me, unfortunately.
Any other hint?
Lily
sgrace
Do you haven to have your C/C++ Build Settings adjusted for targeting the right libraries? I'm assuming you're using the reVISION Platform, which would require SYSROOT and some other includes/libraries to be added.
