leonardo_suriano
creating SDSoC platform for Pynq Board
Following the instruction of the Xilinx's tutorial UG1236, I created a hardware platform for that board.
Also, I use the SW file for the board already tested and working perfectly.
Cases:
1 - creating a HelloWorld project, compiling it in SDSoC, running the application on Linux on pynq -> PERFECT
2 - running the matmul example just in software (NO HARDWARE FUNCTIONS) and running it on Linux on Pynq board -> PERFECT
3 - the problems come when I want to move the function on hardware:
  3.1 - for standalone application -> PERFECT
  3.2 - when compiling to execute on Linux, I have this ERROR MESSAGES:
INFO: [DMAnalysis 83-4494] Analyzing hardware accelerators...
WARNING: [DMAnalysis 83-1005] Invalid clock id 2 for platform pynq
INFO: [DMAnalysis 83-4497] Analyzing callers to hardware accelerators...
INFO: [DMAnalysis 83-4444] Scheduling data transfer graph for partition 0
ERROR: [DMAnalysis 83-4503] No M_AXI_GP port found in the platform!
ERROR: [DMAnalysis 83-4445] Failed scheduling data transfer graph!
XidanePass exited with return code 1
- errors detected
How to fix this problem? Ideas?
Also, a link to a working platform for Pynq board running linux is appreciated. Surfing on the web I have found other platform developed by all of them have the same problem.
huyao4450
I have got similar problem, have you found the cause?
skalicky
Hi Guys,
Heres two working Pynq platforms that ive made and use in my Python + HLS project: https://github.com/ISI-RCG/spicy/tree/master/platforms
The pynq_bare is similar to zc702 platform with nothing in it besides the clocks.
The pynq_hdmi has the HDMI in/out paths connected via VDMAs to DDR.
These platforms are built with the 2017.4 version of SDSoC.
Sam
khareashish_trimble
@skalicky This is great. I've been looking for a Pynq platform for a while.
Do you have any examples on how to use the HDMI in/out in the SDSOC project ?
skalicky
I havent been able to use the HDMI in/out from C/C++ yet. So far ive been running Python applications using Pynq's HDMI API to read/write frames. Then I send these frames from Python down to my SDSoC generated accelerator. Im using the SDSoC library flow to do this.
I havent uploaded any examples of this yet, still cleaning up my code. but i am hoping to upload these examples in the next week or two.
Its not impossible to use the HDMI in/out from C, someone just has to write some drivers to use the VDMAs that are in the platform. Thats probably a longer term solution, but something that I would like to do at some point.
Sam
leonardo_suriano
I am going to test it and I will give you feedback!
huyao4450
Thanks, but do you know why does that error happen?
I am not using a  pynq board and want to create a custom platform, I tryed on zc702 and zcu102 both, when I was creating the platform there is no error, but when I try to compile sdsoc application project on the custom platform I build, this issue come out, could you help me?
vandenplas
I also get the same issue with a custom platform
Did you find the fix?
leonardo_suriano
nope! I think that Xilinx should answer
gill
While this error is where the tool is halting, you very likely saw some suspicious messages related to clock ID prior to the reported error.  Things like this:
WARNING: [DMAnalysis 83-1005] Invalid clock id 1 for platform XYZ
Typically this is the result of a naming mismatch between the platform and the platform's content.  You can encounter this if the platform directory has been renamed, or if the .dsa file internal to the platform has been renamed or was incorrectly exported.  Unfortunately, names are important, and at least today renaming causes mismatches down-stream.
Also, thanks Skalicky for contributions.
bluetiger9
@gill, can you explain this in more details please?
I have a similar problem with the custom platform I'm trying to create for an Ultra96 board:
Generating data motion network INFO: [DMAnalysis 83-4494] Analyzing hardware accelerators... WARNING: [DMAnalysis 83-10051] Invalid clock id 2 for platform ultra96_board WARNING: [DMAnalysis 83-10051] Invalid clock id 2 for platform ultra96_board WARNING: [DMAnalysis 83-10051] Invalid clock id 2 for platform ultra96_board INFO: [DMAnalysis 83-4497] Analyzing callers to hardware accelerators... INFO: [DMAnalysis 83-4444] Scheduling data transfer graph for partition 0 WARNING: [DMAnalysis 83-10051] Invalid clock id 2 for platform ultra96_board ERROR: [DMAnalysis 83-4503] No M_AXI_GP port found in the platform! ERROR: [DMAnalysis 83-4445] Failed scheduling data transfer graph! Data motion generation exited with return code 1 - errors detected sds++ log file saved as /home/bluetiger/dev/XIlinx/SDx/test/Debug/_sds/reports/sds.log ERROR: [SdsCompiler 83-5004] Build failed make: *** [test.elf] Error 1 makefile:45: recipe for target 'test.elf' failed 20:51:31 Build Finished (took 2m:29s.653ms)
It's weird because both the clock with id=2 and ports M_AXI_GP are defined in the DSA.
Vivado / SDK / SDx version: 2018.2
I uploaded the generated DSA in my Dropbox:
https://www.dropbox.com/s/jlggj7nwadjfw44/ultra96_board.dsa?dl=0
Here you can found more info about what I try to achieve:
https://xilinx2018.hackster.io/t/xilinx-revision-support-on-ultra96/870
Can you take a look?
Attila
bluetiger9
No way!
It was the .dsa file / SDx Platform Project name. Apparently, booth needs to be the same as the name from the PFM_NAME...
PFM_NAME = em.avnet.com:ultra96:ultra96:1.2
DSA / Platform Project name = ultra96_board.dsa / ultra96_board
   ===> Weird Error!
DSA / Platform Project name = ultra96.dsa / ultra96
   ===> OK!
Makes lot of sense...
XILINX: It would worth showing an error / warning in Vivado / SDx, when trying to use incorrect names.
mcggoal
great job!  It is such a big trap for our beginners....
khareashish_trimble
Thanks @bluetiger9
I was running into a similar issue for a custom hardware platform for ZCU102.
Certainly looks like SDSoC does not like it when   the .dsa file / SDx Platform Project name are different.
