dsa file open fail
I find the warning information :
WARNING: [BD 41-1731] Type mismatch between connected pins: /v_hdmi_rx/m_axis_video_aresetn_out(undef) and /v_vid_in_axi4s/aresetn(rst)
WARNING: [BD 41-1731] Type mismatch between connected pins: /v_hdmi_tx/s_axis_video_aresetn_out(undef) and /v_axi4s_vid_out/aresetn(rst)
When I use the vivado in tcl console:
open_dsa zcu102_rv_ss.dsa  in revision file
in ZCU104, VCU+ZCU106, ZCU102 MPSOC get the same error
https://github.com/Xilinx/reVISION-Getting-Started-Guide/blob/master/Docs/software-tools-system-requirements.md
My system: Win 10
SDx vision: Vivado 2018.2
Re: dsa file open fail
Hi @mimitter
Yes, you can ignore the warnings.
We have tested multiple examples with this platform.
Best Regards,
Nutan
hi @mimitter
what is the reVISION platform version?
Best Regards,
Nutan
hi :
I use the SDx 2018.2, And Download the 60 days SDx license in Xilinx web.
To rebuild the Vivado Project, I find the warning information when I write open_dsa command in tcl console.
After vivado Succesfully read DSA: zcu102_rv_ss.dsa , I find that the connectors are full connected in the Block Design
this is vivado  information
Hi @mimitter,
I assume you have downloaded the reVISION platform from here,
Currently the platform available at above location is 2018.3, please check which one you have.
Best Regards,
Nutan
@nutang
thank your reply
I download the revision 2018.3 , and run this dsa in SDx 2018.3 in Unbuntu OS, see the same warning information.
And more warning information after key-in the Validate Design .
Could you rebuild the revision example in your environment.
I will re-try  in other PC environment.
Thank you
hi @mimitter
Thank you very much for detailed information.
I will check this and update you.
Best Regards,
Nutan
Hi @mimitter
I observed the warning in my machine too.
Best Regards,
Nutan
hi @nutang:
Thank you, your help!!
So warnings are correct in revision project,influencing  the project implement ??
And I find that interrupts are not full connected in project.
Could  I ignore these warnings ??
Hi @mimitter
Best Regards,
Nutan
