how can I add the sobel filter to revision environment?
hi all:
I  download the ZCU104_revision
and SDX 2018.3
How can I modify the filter2D to sobelfilter  ??
by miter
Re: how can I add the sobel filter to revision environment?
filter2d contains a bunch of filter example in one packet.
You can find the list of filters (including sobel) on the main.c under the "gstdemo" application as a "GstSdxfilter2dFilterPreset" enumeration.
To using that filter in the example, You can change the "FILTERPRESET" definition on line 76 with "GST_SDXFILTER2D_PRESET_VSOBEL" before the building application.
or simply use that command:
gst-launch-1.0 \
xlnxvideosrc src-type="usbcam" ! \
"video/x-raw, width=1920, height=1080, format=UYVY" ! \
sdxfilter2d filter-preset=10 filter-mode=1 ! queue ! \
kmssink bus-id=b00c0000.v_mix plane-id=31
 instead of "./gstdemo"
