Visitor darthsimpson
reVision availabilty for the Ultra96
HI,
Does anyone know with reVision and some sample examples will be available for the Ultra96?
THanks,
Iain
Re: reVision availabilty for the Ultra96
Hi @darthsimpson
We do not have examples for Ultra96.
However, as Ultra96 is based on Xilinx Zynq UltraScale+ MPSoC. You can refer below examples.
https://github.com/Xilinx/reVISION-Getting-Started-Guide/blob/master/README.md
Best Regards,
Nutan
Hi nutang
So should it be easy to re-port the reVision examples to the Ultra96?
Or maybe wait for 2018.3, in which ive been told reVision on Ultra96 will be supported.
Also see the following thread....
https://xilinx2018.hackster.io/t/xilinx-revision-support-on-ultra96/870
Many thanks
DarthS
Ive being trying to comppile for the Ultra96 and get the following error for the opticalflow example surrounding the DMA implementation.... any ideas on how to fix this?
D:\ws_of\opticalflow\Release\_sds\.llvm>opt -disable-output -mem2reg -basicaa -XidanePass --platform ultra96 --dmclkid 3 --repo D:/ws_of/opticalflow/Release/_sds/.cdb/xd_ip_db.xml --dmdb D:/Xilinx/SDx/2018.2/data/DM.db -os linux -processor cortex-a53 -partition 0 0<sds_all.o
INFO: [DMAnalysis 83-4494] Analyzing hardware accelerators...
INFO: [DMAnalysis 83-4497] Analyzing callers to hardware accelerators...
INFO: [DMAnalysis 83-4444] Scheduling data transfer graph for partition 0
INFO: [DMAnalysis 83-4446] Creating data motion network hardware for partition 0
INFO: [DMAnalysis 83-4448] Creating software stub functions for partition 0
INFO: [DMAnalysis 83-4450] Generating data motion network report for partition 0
INFO: [DMAnalysis 83-4454] Rewriting caller code
Creating block diagram (BD)
Creating top.bd.tcl
ERROR: [CF2XD 83-1322] Cannot allocate 'ultra96' interrupt port1
ERROR: [CF2XD 83-2396] Exhausted number of available interrupts. Consider employing axi_dma_simple or zero_copy datamovers.
ERROR: [CF2XD 83-2009] An error has occurred during generation of the system block diagram. For more information, please look for additional ERROR messages in the console and in log files.
Error generating intermediate design file top.xml
Error creating IPI .bd design file, exiting
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'D:/Xilinx/SDx/2018.2/bin/sdx_link -cf-system D:/ws_of/opticalflow/Release/_sds/.llvm/apsys_0.xml -cf-db D:/ws_of/opticalflow/Release/_sds/.cdb/xd_ip_db.xml -xpfm D:/Learn/reVision/Ultra96-2018-2/ultra96/ultra96.xpfm -multi-clks -trace-buffer 1024 -quiet'
sds++ log file saved as D:/ws_of/opticalflow/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [libopticalflow.so] Error 1
06:24:20 Build Finished (took 4m:18s.639ms)
Your platform doesn't have available interrupts.
Make sure your vivado design has xlconcat ips connected to pl_ps_irq0/1
And check  your script  to create dsa is correct for interrupt
