01-31-2019 03:40 AM - edited 01-31-2019 04:36 AM
hi,
I have my own rootfs generated from petalinux, and it includes the opencv, I am trying to develop my vision algorithm based on this opencv in sdsoc, BUT I am getting error about linking opencv with sdsoc. If I use CHaiDNN opencv from here, everything works without any problem. and I have tried to use existing opencv in sdk but I face to the same problem.please help
02-04-2019 09:12 PM
Hi @1ymw1
Please try below option,
Navigate to C/C++ build settings->C/C++ Build-> Settings->SDS++ Linker->Miscellaneous->Linker Flags
Add below line, (If there are other flags already present, please retain)
--sysroot=${SYSROOT} -L=/lib -L=/usr/lib -Wl,-rpath-link=${SYSROOT}/lib,-rpath-link=${SYSROOT}/usr/lib
01-31-2019 02:51 PM - edited 01-31-2019 03:00 PM
Does your sysroot(rootfs) have libopencv_core.so ?
The error message says gcc compiler can't find libopencv_*.so
01-31-2019 07:57 PM - edited 01-31-2019 08:26 PM
hi @hokim,
I generated petalinux rootfs in ubuntu machine and sdsoc is installed in windows machine, as far as I know, if I give the complete link for /usr/lib and /usr/include it is not a problem, right?. if it is not enough can you tell me how to include opencv link to SYSROOT in windows machine, ?
thank you very much for reply.
01-31-2019 08:25 PM - edited 01-31-2019 08:30 PM
I mean you should check filelist in your sysroot directory like this
$ find sysroot -name 'libopencv_core.so*' sysroot/usr/lib/libopencv_core.so
sysroot/usr/lib/libopencv_core.so.3.3 sysroot/usr/lib/libopencv_core.so.3.3.0
Can you see libopencv_core.so ?
If you can't see it , you should check whether your petalinux image recipe includes packagegroup-petalinux-opencv-dev
Image recipe needs *-dev for *.so files
01-31-2019 08:30 PM
Dear @hokim,
yes, I have double checked everytime whether evey *.so files are in the petalinux rootfs /usr/bin and also *.hpp files in /usr/include .
thanks
01-31-2019 08:57 PM - edited 01-31-2019 09:01 PM
I mean libopencv_core.so not libopencv_core.so.3*
Even though libopencv_core.so is actually symbolic link to libopencv_core.so.3.3,
gcc compiler require libopencv_core.so not libopencv_core.so.3* for build
If your rootfs has *.so file, I don't understand why such error message happended
At last, could you build your project on linux system?
Windows system might not treat linux symbolic link properly
02-02-2019 02:36 AM - edited 02-02-2019 02:40 AM
hi @hokim
you are correct, this problem is regarding the *.so files, in the windows *.so files do not linked with *.so.3.3 and *.so.3.3.0 properly. you can see in the images the *.so files and *.so.3.3 files have very less size when they are in windows computer, but these files show big size when they are in linux computer, I think they are not properly linked with each other, so what I did is I convert all the *.so.3.3.0 files into *.so.3.3 and *.so files by renaming *.so.3.3.0 files, in this way I was able to builld my project in sdsoc without any problem, do you think it is a good practise? I get these files from unpacking rootfs.tar.gz in linux computer into pen driver and use these files in sdsoc in windows machine.
02-02-2019 02:42 AM
hi @hokim
02-02-2019 03:00 AM - edited 02-02-2019 03:01 AM
This is how to solve linux symbolic link on Windows
$ mkdir tmp $ cd tmp $ tar xvzf ../rootfs.tar.gz $ zip -r ../rootfs.zip .
linux zip command replace symbolic link with linked file
Use rootfs.zip in Windows
02-04-2019 02:35 AM
Hi @1ymw1
Are you still facing this issue?
02-04-2019 09:00 AM
I am sorry about the late responce, using zip format in windows solved the problem in great degree. but there are few poor *.so files which could not to find the linked files because they were in another directory, for example, in my case, in the libpthread.so, have statements as follow,
/* GNU ld script
Use the shared library, but some functions are only in
the static library, so try that secondarily. */
OUTPUT_FORMAT(elf32-littlearm)
GROUP ( /lib/libpthread.so.0 /usr/lib/libpthread_nonshared.a )
as you can notice here the linked files of libpthread.so are in the rootfs/lib and rootfs/usr/lib but libpthread_nonshared.a was already in the rootfs/usr/lib, so what I did is copied the libpthread.so file from rootfs/lib to rootfs/usr/lib and change the statement "GROUP ( /lib/libpthread.so.0 /usr/lib/libpthread_nonshared.a )" to this "GROUP ( libpthread.so.0 libpthread_nonshared.a )"
And I did the same thing to the libc.so as follow
"GROUP (/lib/libc.so.6 /usr/libc_nonshared.a AS_NEEDED ( /lib/ld-linux-armhf.so.3) )" to
"GROUP (libc.so.6 libc_nonshared.a AS_NEEDED ( ld-linux-armhf.so.3) )"
and I copied te libc.so.6 and ld-linux-armhf.so.3 from /rootfs/lib to rootfs/usr/lib
in this way I was able to compile my code sucessfully. But I need to know that is this the correct way to do this? will this cause to future problem??? I am going to develop my whole algorithm on sdsoc,so I need to verify that I have done everything in correct way.
and Dear @hokim you have been very kind to me. you have tried to give me a solution for many cases, thank you. thank you so much.
02-04-2019 09:12 PM
Hi @1ymw1
02-04-2019 09:49 PM - edited 02-04-2019 09:50 PM
hi @nutang
I re-extract my rootfs.zip and tried your script for linker flag, but it didnt work, I am using sdsoc(2018.2) in windows computer and I generated rootfs.zip in linux computer, compiler says,
cannot find /lib/libpthread.so.0
cannot find usr//lib/libppthread_nonshared.a
please read this thread from beggining. thanks
02-04-2019 10:00 PM
hi @1ymw1
This is the correct way to link the pthread library in run time, I have tested it multiple times.
If you have set $SYSROOT properly,
clean and build again.
02-04-2019 10:02 PM - edited 02-04-2019 10:04 PM
hi @nutang
can you please tell me how to set $SYSROOT in sdsoc in windows machine? ussually I give the complete path to the rootfs folder. example:
c:/rootfs/lib
c:rootfs/usr/lib
thanks
02-04-2019 10:06 PM
Hi @1ymw1
02-04-2019 10:07 PM
Hi @1ymw1
Which platform you are using?
02-04-2019 10:22 PM
hi @nutang
wow, it works...... needed to restart the software. no need to change the content in any of the *.so files. thank you so much.
02-04-2019 10:24 PM
Hi @1ymw1
I am glad that it helped you.
02-04-2019 10:26 PM
hi @nutang
I am using zedboard, with my own rootfs generated in petalinux with opencv. I added variable name with SYSROOT and c:\rootfs
thanks again for the concern
