successful in sdsoc,but failed in ZCU104 fpga,error: cannot add more entries to request queue associated with id 1
my code looks something like this:(many for loops )
main
   for( 4)
      for (int xShift = 0; xShift < R * 2; xShift = xShift + h)
          for (int yShift = 0; yShift < R * 2; yShift = yShift + h)
           #pragma SDS async(1)
              for (int row = 0;row < rowNum; row++)
                for (int col = 0; col < colNum; col++)
                   foo1:
             #pragma SDS wait(1)
             foo:,,,,,,
             #pragma SDS async(2)
                  foo2:
             #pragma SDS wait(2)
 many for loops in for loops,
the result my code running  in fpga is :
i think,maybe my code for loop is too much, out of the number of async uses ,but,for loop is must,  how should i modify my code so that my code compiles properly?
that's noted that my hw function can;t hold any more for loop .
my hw  function ,such as :
void fftshift_adaptive(int dx, int dy,float *l_real,float *l_imag, int rowNum, int colNum, int R)
	int start = (dx * colNum + dy) * R * 2 * R * 2;
	for (int ref_row = 0; ref_row< R; ref_row++)
		for (int ref_col = 0; ref_col < R * 2; ref_col++)
			#pragma HLS pipeline
			int dst_col = (ref_col < R) ? ref_col + R : ref_col - R;
			int dst_row = ref_row + R;
			float temp;
			int exchenge1 = start + ref_row * R * 2 + ref_col;
			int exchenge2 = start + dst_row * R * 2 + dst_col;
			temp = l_real[exchenge1];
			l_real[exchenge1] = l_real[exchenge2];
			l_real[exchenge2] = temp;
Somebady help me, i'm going crazy :(
Re: successful in sdsoc,but failed in ZCU104 fpga,error: cannot add more entries to request queue associated with id 1
Hi @mu_yu
First mistake in your code is location of async pragma.
The ASYNC pragma should be specified immediately preceding a call to a hardware function.
https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2018_2/ug1253-sdx-pragma-reference.pdf
Please refer below example.
Best Regards,
Nutan
thanks for your reply very much,
i tried to comment out all the "#pragma async"comments, and the result was that it would print as normal,but when the 96th iteration,the program terminates.
and there are no nothing errors or prompts.
that's why?
is it because i have applied for hardward functions too many times?
resulting in insufficient memory on the pl side,?
or , maybe, because  i was writing pragma code is wrong?
my hw function .h file such as :
#pragma SDS data zero_copy(l_real[0:rows * cols],l_imag[0:rows * cols],r_real[0:rows * cols],r_imag[0:rows * cols],s_real[0:rows * cols],s_imag[0:rows * cols]) void fpgaCrossPower(float *l_real, float *l_imag,float *r_real, float *r_imag,float *s_real,float *s_imag,int rows,int cols);
 have you ever had such a problem??no errors were reported,but the program did not run on the fpga platform(zcu104).
Hi @mu_yu
SDSoC will not give errors for pragmas as Pragma is considered as rule.
That's why you did not get any error when it was placed wrong.
1. When you are using zero_copy, it is mandatory to use sds_alloc for memory allocation
Refer this example https://github.com/Xilinx/SDSoC_Examples/tree/master/cpp/getting_started/hello_vadd
Best Regards,
Nutan
of course, that's what i do ,every zero_copy , i use sds_alloc for memory allocation, such as : float * D_leftImage = (float *) sds_alloc (sizeof(float) * height * width); float * D_rightImage = (float *) sds_alloc (sizeof(float) * height * width); //set 0 float * l_real = (float *) sds_alloc(sizeof(float) * 2 * R * 2 * R * rowNum * colNum); float * l_imag = (float *) sds_alloc(sizeof(float) * 2 * R * 2 * R * rowNum * colNum); float * r_real = (float *) sds_alloc(sizeof(float) * 2 * R * 2 * R * rowNum * colNum); float * r_imag = (float *) sds_alloc(sizeof(float) * 2 * R * 2 * R * rowNum * colNum); float * s_real = (float *) sds_alloc(sizeof(float) * 2 * R * 2 * R * rowNum * colNum); float * s_imag = (float *) sds_alloc(sizeof(float) * 2 * R * 2 * R * rowNum * colNum); float * res = (float *) sds_alloc (sizeof(float) * height * width * 2); float * hamming = (float *) sds_alloc (sizeof(float) * 2 * R * 2 * R); if sdsoc doesn't give errors as pragma is considered as rule ,maybe ,it's not because i'm using zero_copy. could it be something else,
such as :
//set 0
i wonder if calling hardware function too many times is allowed?
or,is it possible that there isn't enough memory on the pl side?
if the platform encounters these two situations ,will it not give an error?
Hi @mu_yu
Can you please tell me the exact error?
Best Regards,
Nutan
i'm so sorry,maybe,i didn't make myself clear.
now,i try the following scheme:
			printf("init6 is start !  %d**%d**\n",yShift,xShift);//////slower
					devMemCopy_adaptive(row,col,D_leftImage,D_rightImage,l_real,l_imag,r_real,r_imag, height, width, rowNum, colNum, R, xShift, yShift, lastLevelRes, hamming);
			for (int i =0; i <rowNum*colNum; i++)
				#pragma SDS wait(1)
			printf("init7 is start !\n");
debug is successful,but running on  the zcu104, the program is stuck,it doesn't work when running the hw function,and no any indications.
such as,
the zcu104 printed "init6...." a long time ago.
but no "init7",and no any indications.
Hi @mu_yu
Please add some print statements for each for loop after init6
Best Regards,
Nutan
