取消
显示结果
搜索替代
您的意思是:
788 次查看
注册日期: ‎07-24-2018
xfopencv 中xf::resize()问题
转到解答
在xfopencv例子中用xf::resize()函数,
makefile中描述为-sds-hw "xf::resize <2,  0, 2160, 3840,1080,1920, 1, 2>"  xf_resize_accel.cpp -files ../../include/imgproc/xf_resize.hpp -clkid 2 -sds-end -dmclkid 2
把xf_resize_tb.cpp中第69行改为static xf::Mat<TYPE, 480, 640, NPC1> imgOutput(480,640);编译过程中会报错,错误如下
[zhengjia@hw53 resize]$ make
sds++ -sds-pf /home/zhengjia/SDSoc/platform183/zcu102_rv_ss/ -sds-hw "xf::resize <2, 0, 2160, 3840,1080,1920, 1, 2>" xf_resize_accel.cpp -files ../../include/imgproc/xf_resize.hpp -clkid 2 -sds-end -dmclkid 2 -O0 -Wall -c -I. -I/home/zhengjia/SDSoc/platform183/zcu102_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux//usr/include -I ../../include -DHLS_NO_XIL_FPO_LIB -mstrict-align -hls-target 1 xf_resize_tb.cpp -o xf_resize_tb.o
Platform system configuration option -sds-sys-config was not specified, searching for a configuration that uses the specified OS linux
Using system configuration -sds-sys-config a53_linux
Analyzing source for RTL template usage
/home/zhengjia/SDSoc/sdsoc183/xfopencv/xfopencv/examples/resize/xf_resize_tb.cpp:80:2: error: no matching function for call to 'resize_accel'
resize_accel(imgInput, imgOutput);
./xf_resize_config.h:49:6: note: candidate function not viable: no known conversion from 'xf::Mat<XF_8UC1, 480, 640, XF_NPPC1>' to 'xf::Mat<XF_8UC1, 1080, 1920, XF_NPPC1> &' for 2nd argument
void resize_accel(xf::Mat<TYPE, HEIGHT, WIDTH, NPC1> &_src, xf::Mat<TYPE, NEWHEIGHT, NEWWIDTH, NPC1> &_dst);
Error while processing /home/zhengjia/SDSoc/sdsoc183/xfopencv/xfopencv/examples/resize/xf_resize_tb.cpp.
ERROR: [TemplateExtract 83-3509] Failed to run clang frontend action of rtl_template_extract!
ERROR: [SdsCompiler 83-5176] RTL template analysis exited with non-zero code processing /home/zhengjia/SDSoc/sdsoc183/xfopencv/xfopencv/examples/resize/xf_resize_tb.cpp
sds++ log file saved as /home/zhengjia/SDSoc/sdsoc183/xfopencv/xfopencv/examples/resize/_sds/reports/sds_xf_resize_tb.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [xf_resize_tb.o] Error 1
请问如果makefile中描述的转换图像大小确定后,就不能再改变resize输出的图像大小吗?必须输出设置为1080*1920吗?不支持输出大小大小的任意变换?附件为压缩包,其它文件未改动
0 项奖励
1 个已接受解答
已接受的解答
725 次查看
注册日期: ‎05-11-2010
回复: xfopencv 中xf::resize()问题
转到解答
你可以这样试一下么?
static xf::Mat<TYPE, NEWHEIGHT, NEWWIDTH, NPC1> imgOutput(480,640);
1 条回复1
726 次查看
注册日期: ‎05-11-2010
转到解答
你可以这样试一下么?
