trisita92
7 series transceiver wizard 3.6 example
hello .i am working on kintex -7 fpga kc 705. can anybody give me any example design on the 7 series transceiver wizard 3.6 . any pdf or any documnet . the step by step procedure
eschidl
Hi @trisita92 ,
please give PG168, especially chapter 4 and 5, a look. They describe the core setup and example design.
karnanl
Hello @trisita92
Do you have any updates on this post ? Is @eschidl's answer  enough for you ?
If you find @eschidl  answer is useful, could you please kindly marked this thread as Solved , so other users can learn from your experience ?
Thanks & regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
