7z015 GTP SFP not work
hi ,I  currently  have designed a board for the 7Z015 .using GTP interface to SFP .
1.I connect the ETH interface of PS through EMIO mode. then used IP “1.5G/2G eth pcs/pma or SGMII ".this IP output SFP, I connect it directly to GTP interface, but the network has been impassable, can not find the reason.
2.In hardware design, we use two SFPs, that is, two optical ports, SFPA and SFPB.The 125M clock of GTP is generated by an external crystal oscillator. The power supply MGTAVCC is 1.2V. MGTAVTT is 1.0V
3.i_mgt is 125M, which is directly connected by the crystal oscillator described above. Independent CLK bufg of two IP is 200M, which is output by FCLK1 on PS side.
4.Phy_address is set to 0 and signal_detector is set to 1.
Re: 7z015 GTP SFP not work
There is sometimes an enable port on SFP that can be overlooked.  Also check that your PLL*PD is getting set low.
Roy
Roy
Hi,Roy.  I have set net sfp_tx_disable to "0" in my bd design,also connect  the pin to GND  in my harware PCB.
I used only IBERT 7 series GTP ip  to test my 7015 GTP interface wherther work  normal or not.  I create links and add 4 channels  X0Y0 X0Y1 X0Y2 X0Y3 to my link groups,then do internal loopback test.But  the result shows that  my GTP work unnormal ,some channels can not pass the test.  Even I click IBERT reset,it can not normal , I must click TX reset and RX reset some times ,then it work normal and pass the loopback test.result.png
My problem has been solved. The hardware PCB package reverses SFP's TX and rx.
