Artix-7 GTP Transceiver
           If I am not planning to use the GTP transceiver functions at all in the Artix-7, can we I tie all the GTP pins to GND?
Re: Artix-7 GTP Transceiver
hi @suvanb1987 ,
Thanks for contacting Xilinx forum support .
If none of the GTP Quads in a power supply group are used in the application, the GTP Quad device
pins can be connected as shown in Table
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
hi @suvanb1987 ,
Chandra sekhar
