Aurora 8B10B link cannot connect sometimes
I included one Aurora 8b10b IP on two FPGA boards' firmware.
When these two FPGA boards' GTP transceivers are connected, both firmware should have "channel_up" HIGH automatically, which means the link is connected. As shown in the IP manual:
The sequence of Aurora IP's reset and gt_reset I applied is:
reset-0, gt_reset-0
delay
reset-1, gt_reset-0
delay
reset-1, gt_reset-1
delay
reset-1, gt_reset-0
delay
reset-0, gt_reset-0
Sometimes "channel_up" doesn't go HIGH after this sequence of reset and gt_reset, but if I apply this sequence one more time, channel_up will recover.
The possibility of first time success is ~2/3.
Thank you for any replies.
Have you used IBERT with your GTP settings to check your link performance/BER/etc.?
Cheers,
bt
Yes, IBERT test is pretty strange too.
With PMA loopback mode, the IBERT tests pass, both in near-end and far-end.
But with PCS loopback mode, the link shows connected, the link transmit speed is right, but with a lot of transmission errors.
Hi @jiongsi ,
Are you follow Power On reset Sequence ?
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
I tested the power voltage to the GT bank after powered on, it looks stable and no noise.
Did you test it at the time of failure?  If so, see what the Eye Scan looks like.
