alexis_jp
Can I safely connect TXOUTCLK of a channel to TXUSRCLK of 2-3-4 GTY channel modules?
I'd like to use the same TX user clock to drive two instances of the same GTY module located in the same QUAD connected to the same QPLL (QPLL0) with TX/RX buffer bypass.
The GTY common is shared among the 4 channels of the quad.
UG578 - Using TXOUTCLK to Drive the TX Interface
There is a note regarding the TX phase alignment circuit, does it mean I can't use that clock for a different channel?
  • Can I safely connect TXUSRCLK/2 of both gty channels from one of the 2 TXOUTCLK?
If not, what's the best practice to use the same TX clock generated by one of the two (up to 4) GTY channels?
karnanl
Hello @alexis_jp
I don't see any issue on this case.
I assumed that all GTY channel has the same configuration.
Thanks & regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
karnanl
Hello @alexis_jp
Thanks & regards
Leo
alexis_jp
@karnanl
Exactly they have the same configuration.
That's perfect, thank you!
